Hello there,
I have noticed when driving down the motorway for 30 minutes at around 70 mph I get the engine warning light flashing a few times then it goes off after about 10 seconds.
I have an OBDII dongle which I used to see if any errors have been logged. I found that cylinder 2 & 3 we're misfiring. Therefore I replaced the spark plugs and made sure that all cables were correctly in place. However the problem still existed so I replaced the coil pack, which still showed the errors so I swapped the leads round (1 with 2 hoping that if it was the leads then it would misfire under 1)
I'm stuck to what to check next, ECU?
