Technical Intercooler hose (not the usual one!)
Chesterfield, Derbyshire
One of my turbo to intercooler hoses has split, and it's not the 90 degree elbow one which seems to be a common failure.
It's the short one after the metal pipe which attaches directly to the turbo side of the intercooler, the rubber part of pipe number one on the picture.
I can't seem to find a replacement for this anywhere online and wondered if anyone could help?
Jacob
https://www.fiatforum.com/attachment.php?attachmentid=138599&stc=1&d=1402845131
That's the one off eper, not sure why it's so small :/
Because I only want the 1 rubber section, I believe the dealers only sell the whole section with a metal pipe and 2 rubber hoses at great expense.
Which section is it under on eper. If it's the pipe I split that you are talking about then fiat only sell it to you as a kit of two pipes. I fixed it for about £14 in the end.
I'll check the eper again when I'm back at my computer for you.
So the set up is turbo-90 degree elbow-metal pipe-short hose-imtercooler.
Its the short hose directly before the intercooler that's split.
Its a bit of an odd shape with a couple of different angles in so not sure if a non oem hose would fit.
Ye it was the pipe I thought it was. I bought a 45 degree bend silicone pipe and then kept cutting it down bit at a time to fit. Held each end with jubilee clips. There obviously isn't a fixing on this pipe like the original though so it's being held on using a cable tie and so far no problems. I got this 48mm fluoro lined pipe from eBay hope this helps.
http://m.ebay.co.uk/itm/270665040997
Brilliant mate thanks!
What did you trim it with, just a Stanley knife or something?
I've already ordered the 90 degree from them for the hose before this and seems like decent stuff so might just have a crack with that one too, 17 is a bit cheaper than 72 which is the cheapest I've found from a dealer.
Jacob ye just cut back a bit at a time and keep offering it up. I did the same because I wasnt sure which I'd need so I've still got the 90 degree bend to change at some point when I can be bothered. Glad to have helped I nearly bought the forge kit which although it will be good I can't justify that much of a price difference for a bit of silicone piping.
Thats the one that always splits what a stupid shape
Yeah I looked at the Forge hoses but £176 is too much for me! I asked if they'd sell the one I was after separately but no luck.
I'll have a crack at getting it sorted after the weekend, thanks again mate.
