S spawnstar New member Joined May 11, 2014 Messages 1 Points 1 May 11, 2014 #1 I have what should be a very simple problem. I need to jump start my car. How do you get a good connection on the positive terminal?
C ck247 New member Joined Mar 5, 2014 Messages 153 Points 26 Location helensburgh (argyll) May 11, 2014 #2 Check the terminals tight on the battery, if not spray white grease onto it to avoid corrosion, if not the battery is on its way out
Andy Monty Moderator Staff member Parked in the garage Written 10+ guides Joined Apr 30, 2006 Messages 16,904 Points 3,632 Location East Yorkshire May 11, 2014 #3 best thing to do is charge the battery off the car,.... reduces the risk of spiking the ecu or BC......... as for a good connection on the + terminal ive never had a problem,.......
