I discovered both front footwells were soaking wet through a few weeks ago, so I took the seats out removed the carpet and dried it all out thoroughly.
At the same time I bought the longer drain hose for a Mito and installed that and sealed it in place so no water could run down around where it fits in.
I also tigersealed the rusted servo plate so that should now be watertight as the trough is filled and the surface of the plate is covered in tigerseal. I also tigersealed the black plastic cover in place so that should also be waterproof.
Just went outside after a big rainstorm and checked the car - wet through driver's foot well again!!!
I've looked online but all I can see is the servo plate issue which I've already fixed using the guide on here so it shouldn't be that anymore.
Does anyone have any ideas as to where this rainwater is coming from?!
It isn't coolant or ac fluid or anything from the car itself, it's definitely rainwater and the car was parked up so it's not a seam under the car.
If anyone has any ideas that would be great as I'm really lost with this one?!
