Technical Multi Ecu Scan
Hey guys I've brought a elm 137 cable and the 3 adapters but I can't get it to find and reset the fault code on my t-jet.
It won't let me connect but only run the simulation mode as it says I have to upgrade, is this right?
use the bottom left (F9..?) button,
then do a TEST of connectivity.. are you using KKL ir ELM,
High latency is a common bugbear..!!, :bang:
Charlie
Simulation mode does not reflect your engine parameters. It will run even without the cable connected and just give random figures
Mine is registered and has worked perfectly with a load of different cars.
I have a registered version and I have connectivity issues. The obd is connected to the laptop but the ecumultiscan doesnt like it, after messing with the settings it almost tries to connect then complains about reliability issues or says it cannot connect at all.. A google search has led me to believe the elm units are the problem! Mine is bluetooth though, so my problem could be different to yours.
All my interfaces have been usb to tell you the truth. I don't trust bluetooth all that much.
This is the kit I use as regards hardware.
I know mate, all the PC settings are correct.
I went back on to ecu scan and realised some modules come up in read and some in blue.
Are the ones in blue free to access and red ones you have to upgrade?
Yes, that's exactly what the red and blue listings mean.
I've never bothered trying to use it unregistered - it's amazingly cheap to register considering what it does, and it takes only a few minutes to get it up and running. Yani has invested his livelihood in developing the software to support practically every FIAT and Alfa Romeo model anywhere in the world.
A few years ago, badly-written professional software, that worked with only a few ECUs, was priced into four figures :)
-Alex
