General Roof Rack/cycle carrier Help
adamc123
I know this might be a really stupid question, but im looking into getting a roof box.
What do i need to be able to fit it just roof bars or is there something else i need, Ive got a 57 plate 5 door GP.
Also does anybody have any advice on cycle carriers that go on the boot, is a low rack or high one better? As ive read that depending on where the lights are i might need a lighting board?
if you dont have a glass roof your looking at something like this
https://www.fiatforum.com/grande-punto/236813-roof-racks-carrying-bicycle.html?p=2490973
as for strap on rear carriers have a read of this
https://www.fiatforum.com/grande-punto/198292-cycle-carrier-light-board-wiring.html?p=2126972
i use a towbar mounted rack with a lighting board
attachment.php
Ok thanks for your help
are the parts below all i need for the full setup?
Gutterless Foot Pack
Part #: 750
Bars - 120cm
Part #: 761
Rapid Fitting Kit
Part #: 1413
And then for the cycle carrier i think the roof mounted one would be better for me would i just need the thule 591 and that will be compatible with the bars above?
Part #: 750
Bars - 120cm
Part #: 761
Rapid Fitting Kit
Part #: 1413
An alternative would be to buy some Atera bars. They come with the correct fittings and pre set to the correct length. I'm pleased with the quality of mine. http://www.roofbox.co.uk/scripts/rb...RWIwrn9tMXqlrqLaHLTI}B~d5ZKmNN`{Hoi{LX5sbKle,
I'd avoid a boot mounted bike rack if possible. The straps mark the paint, and you will make a mistake and touch a pedal or handlebar on the car whilst loading one day.
Has anybody had problems with the fitting kit?
Ive got the fitting kit, its the right one for my 5 door grande punto. But the ,measurements in the instructions seem to small , it just doesnt fit,
Should the black rubber base go into the groove on each side ?
Is there an easy way to do it or am i clearly doing something wrong?
