Old 13-01-2014   #1
Replaced front brake pads but now no brake pressure
Replaced my front brake pads and now there is no brake pressure, the fluid is above the minimum level and I have attempted to pump the brakes yet the pedal has to travel very far before the car brakes properly any ideas?
Lukejenks is offline Reply With Quote Quote
Old 13-01-2014   #2
Re: Replaced front brake pads but now no brake pressure
Did you open the bleed nipples at any point? Could have got some air in the braking system. I'd say you need to bleed the brakes, the fluid should be changed every 2years anyway so it won't be a total loss.
James
2007 T-Jet Sporting, Red, Skydome
jameshobiecat is offline Reply With Quote Quote
Old 13-01-2014   #3
How do I go about bleeding the brakes?
Old 13-01-2014   #4
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Have you put them back together properly?
how did you reset the piston?
did either piston pop out whilst you was working on them?
did you open the bleed nipple?
with the wheels off are the pads moving
Did you replace the disc? and if so was it an identical disc (there are 2 disc types for the GP one is thicker (vented) than the other ((solid))
did you hang the callipers by the hose? did you kink the hose at any point?
Massive gash
Just a little touch up
Old 14-01-2014   #5
Quote Originally Posted by Lukejenks View Post
Perhaps at this point it would be best to seek help from someone who knows what they are doing, you don't want to take chances with the brakes. Get them to look the brake installation over as well as doing the bleeding.
Rather than me trying to describe the bleeding process, I'd bet a YouTube video exists (doesn't have to be a gp, all cars are a similar process).
(G) Best front brake pads? ArranFlint Punto (Mk2/2b) 3 01-07-2013 01:04
(T) Front brake pads Dan87 Punto (Mk2/2b) 6 13-10-2010 11:23
(G) front brake pads hayleylulu Ducato 2 16-03-2010 12:35
(T) front brake pads kingy2184 Multipla 1 13-08-2009 12:24
(G) Replaced front brake pads, now they are squealing! gearfinger Stilo 22 02-06-2006 15:12
