FIAT Auto Specialist Team
Thread Tools
Old 09-12-2013   #1
How to reset the ECU on Fiat Punto Grande
How do you reset the ECU on 2007 Fiat Punto Grande 1.4? I have disconnected the battery and left it for about 3 hours, but when I reconnect the battery and start the car the engine management light is still on? Also which fuse number is the ECU on?
SteveGriff10 is offline Reply With Quote Quote
Old 09-12-2013   #2
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: How to reset the ECU on Fiat Punto Grande
If the engine management light is on then the ECU is detecting a fault....which needs fixedl
IF you have previously fixed a fault then the car will need 3 drive cycles and if it does not detect the fault then it will extinguish the light.
Old 09-12-2013   #3
Bee Eater Champion
Quote Originally Posted by SteveGriff10 View Post
I had an engine fault for a while. I can't remember what the code was.
It was a Turbo fault basically.
My guess was a clogged up EGR valve.
1st time it happened I called out the breakdown guys who resetted it for me.
2nd time I did the same as above
3rd time I left it be and it eventually went off after 1 week.
The 3 faults were about 6-7 month apart and happened over just under 2 years.
Welcome to the frustrations but good rewards of having a GP
go hard or go home
2006 - Grande Punto - Red - 1.9 Multijet Turbo Diesel
rayrayli88 is offline Reply With Quote Quote
Old 09-12-2013   #4
Forum Moderator
T14086's Avatar
T14086 has donated!
Theres nothing frustrating about owning a GP, if the engine light is on then there is a fault (that is why it is there) the same as any other make of car....it needs checked!.
Thanks ChrisUK thanked for this post
Likes Most Easterly Pandas, james44422 liked this post
Old 11-12-2013   #5
I have replaced the old faulty parts and now the fault has disappeared, but the engine management light is still on. So I need to reset it or the ecu. Any ideas?
Old 11-12-2013   #6
Bee Eater Champion
You got breakdown services?
The guys there usually have a 200 hand held scanner/reader.
Will reset the fault code and clear it.
Takes 2 mins.
go hard or go home
Old 11-12-2013   #7
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Should auto reset the light I believe, it staying on means there is still a fault somewhere, I'm sure someone else will probably be able to confirm if I'm correct or not.
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 11-12-2013   #8
But the original fault has disappeared and the car runs fine now.
Old 11-12-2013   #9
If you've fixed the fault for sure, then the EML light should extinguish after a while.
Usually about 50 miles, or a number of stop start cycles.
Basically, when the ECU believes the fault has gone for sure, and is not coming back, it will turn out the light.
However, even though the car may be running right, or you feel that it's running right, the ECU might say otherwise, then no amount of the above will clear it.
The ECU is monitoring hundreds of components, it only takes a fault on one to put the light on.
The only way you'll know is to have the codes read, note them, clear them, and see if the fault comes back.
Incidentally, the single yellow light means that 1 or more of about 2000 errors has been detected.
Driving like an idiot and meeting another one coming in the opposite directions has dire consequences.
keat63 is offline Reply With Quote Quote
Old 11-12-2013   #10
DIY Mechanic
chricol's Avatar
chricol has donated!
Malta
fault light still on = real fault still present. end of story. You might have cleared one fault but still have something else you are not aware of. get it scanned and fixed, the engine light will go out by itself if nothing is wrong with the car.
chricol is offline Reply With Quote Quote
Thread Tools
(T) punto mk2 1.2 8v .. Reset ecu? cookski Punto (Mk2/2b) 10 21-03-2012 15:01
(T) Grande Punto ECU Reset AJKelly Grande Punto 7 19-11-2008 14:02
(G) Punto JTD ecu reset Jasperado Punto (Mk2/2b) 9 05-07-2007 09:38
