![]() | #1 | ||
Posts: 9 Thanks: 0 Trader Rating: 0 ![]() | How do you fit a replacement rear passenger door window regulator? The rear manual Window regulator as broken on my Grande Punto 2009, can anyone possibly tell me how to replace it please: i looked on the Forum but can't really find any specific instructions for this. many thanks carl.
![]() | #2 | ||
Posts: 59 Thanks: 0 Trader Rating: 0 ![]() | Re: fit a replacement rear passenger door window regulator Yeh its a peice of piss really, take off the door card, this is dont by 2 alan keys under the door card arm rest, one alan key bolt hidden by a cap under the door handle and 2 small phillips screws at the bottom. Then pull off the small retaining clip behind the window winder hangle, just pry it with a small screw driver and it will come off just do it with the door shut though in case it drops on the floor as it is small. Then just pry the door card off and the retaining clips will pop out and the door card will hang off. Then undo the 2 nuts holding the regulater in place and pull the small plastic clip out that is in the hole in the bottom of the glass, its really easy even if it sounds complicated. Then just pull out the hold one, put in the new one and clip the plastic clip in the glass, bolt it back in place and put the door card back in.
![]() | #3 |
Posts: 582 Thanks: 32 Trader Rating: 0 ![]() | Re: How do you fit a replacement rear passenger door window regulator? A pretty simple job, good luck! ![]() |
![]() | #4 |
Posts: 3,291 Thanks: 148 Trader Rating: 0 ![]() | Re: fit a replacement rear passenger door window regulator It really is simple and self-explanatory once the door card is off just don't lose the wee pin the holds the window winder on mate! Regards Stephen
__________________ ![]() “Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.” Instagram: 1985SJB |
![]() | #5 | ||
Posts: 9 Thanks: 0 Trader Rating: 0 ![]() | Re: fit a replacement rear passenger door window regulator ...brilliant thanks very much, appreciate your time - i've been putting it off for a while now as i thought it would be complicated and tricky , i'll order one from ebay and bang it in this weekend. cheers carl.
![]() | madbilly | Grande Punto | 13 | 05-11-2019 15:08 |
![]() | budokan | Grande Punto | 0 | 22-09-2011 21:08 |
![]() | mallettron | Punto (Mk2/2b) | 5 | 01-03-2011 17:27 |
![]() | msharples0782 | Bravo / Brava | 2 | 01-09-2009 17:46 |
