Old 09-11-2013   #1
Coolent keeps going down?
My coolent keeps running out and there don't seem to be a leak can some one help
Stifler3513 is offline Reply With Quote Quote
Old 09-11-2013   #2
Re: Coolent keeps going down?
Hi, If your coolant is going down, it can be only 2 things an external leak or an internal leak. Check the inside of the oil filler cap and/or the dipstick for 'Mayonnaise' Brown/white sludge on either of these probably means there is a problem with coolant getting into the engine. If you have checked everywhere and cant see any obvious external leaks, check the Y shaped metal coolant pipe which is sandwiched between the exhaust down pipe and engine block. This particular pipe corrodes easily and its difficult to see due to its location. The pipe may be weeping or dribbling out and where it is situated between the hot engine and exhaust, the coolant is maybe evaporating before it shows an obvious leak on the ground. Or its getting splashed on the hot engine/exhaust when the car is moving, hence the difficulty of spotting a leak.
Remember that when the engine is running the coolant is under pressure, so it is easier to find a leak. When the engine is cold obvious leaks are difficult to spot. If this particular pipe is the cause , you can buy one online for about 30. Hope this helps.
colbar72 is offline Reply With Quote Quote
Old 13-11-2013   #3
Ive always had the same problem, it always drops to the minimum level, never goes below just stays there despite how many times i fill it. Is that the same issue as yours or is yours completely going? If it's going check what the post above said, if not then just ignore like me and I've covered 20k and never had a problem yet
Sm1thygp is offline Reply With Quote Quote
Old 14-11-2013   #4
Mjet220 has donated!
Ive replaced every pipe and yet this still happens taken it in to garage 3 times yet it still vanishes
Mjet220 is offline Reply With Quote Quote
Old 14-11-2013   #5
Malta
Once i had this problem and the problem was coming from the filler cap.It was old enough that it wasn't sealing tghitly.
marea sx is offline Reply With Quote Quote
Old 14-11-2013   #6
Anti-lag ftw!
Reuuk's Avatar
Trader Rating: 1
Reuuk is part of the official FF Events Team :)
Reuuk has donated!
Babe Jump Champion, Sofa Longjump Champion, Space Explorer Champion
My coolant was also dropping down frequently. Replaced the coolant tank cap and it doesn't move any more. The the price of the cap from shop4parts it's worth a shot only about 7 posted
Reuuk is offline Reply With Quote Quote
Old 15-11-2013   #7
Im sure its the cap lettin it escape, ill try tht
(T) coolent boiling over ??? roathy17 Cinquecento / Seicento 7 25-02-2012 19:19
(G) Coolent temp lucapetrone Grande Punto 2 15-01-2012 19:43
(T) coolent problem!! benjii Panda (Classic) 25 29-04-2011 18:30
(G) What coolent do you use? MadMan0 Punto (Mk1) 3 07-06-2010 16:47
(T) Coolent Silver_Sei Cinquecento / Seicento 2 14-09-2003 04:32
