Thread Tools
Old 24-10-2013   #1
Warped discs
Hi all. My grande punto 1.9 seems to be eating the front discs. I've got through 2 sets of discs and they have both warped, luckily first set was done under warranty but I can't ask for these to be done under that too. Any ideas if it's poor quality discs? Or my driving or if it could be a faulty part else where. Cheers for any help
Sm1thygp is offline Reply With Quote Quote
Old 24-10-2013   #2
Re: Warped discs
Quote Originally Posted by Sm1thygp View Post
Maybe standing-on hot brakes when waiting for lights to change.
On-the-move - best to dab-dab, dab-dab. Some take-the-p*ss for doing it - but discs last forever.
241156Z
Caravadossi is offline Reply With Quote Quote
Old 24-10-2013   #3
Moderator
dombooth is part of the official FF Events Team :)
dombooth has donated!
dombooth is an honorary friend of the forum :)
DiffSpotter 3 - Rooms Champion
Re: Warped discs
When you're stopped are you holding it on the brakes or the handbrake?
Are you constantly braking hard?
Dom
Current Car: FIAT Bravo 150T Sport
And the mighty Fiat 126!
dombooth is offline Reply With Quote Quote
Old 24-10-2013   #4
Re: Warped discs
I do a lot of motorway miles, 44 a day and sometimes I sit on the brakes yeah. Would that be the cause?
Old 24-10-2013   #5
Anti-lag ftw!
Reuuk's Avatar
Trader Rating: 1
Reuuk is part of the official FF Events Team :)
Reuuk has donated!
Babe Jump Champion, Sofa Longjump Champion, Space Explorer Champion
Re: Warped discs
i would say its down to poor quality brake disc's personally. what symtoms are you having?
follow me on Instagram: @reuuk
Mini Cooper S & Abarth 500
Reuuk is offline Reply With Quote Quote
Old 24-10-2013   #6
Re: Warped discs
When travelling at a low speed you can feel it brake harder then will go back to normal then harder, like a pulsation but not through the pedal, I can just feel it
Old 24-10-2013   #7
Take the discs off, clean the hub surface behind and re-fit.
jameshobiecat is offline Reply With Quote Quote
Old 24-10-2013   #8
Re: Warped discs
Well I've just put new discs and pads on, the drivers side was easy but the passenger side was harder, kept binding so had to strip it all down, clean it and take off the pad shim thing off the back and apply copper grease to prevent brake squeal but all is well now, no pulsation. Il just remember not to sit on the breaks! Cheers guys
Old 24-10-2013   #9
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: Warped discs
if its binding is it only the left side that is warping?
Massive gash
Just a little touch up
Old 24-10-2013   #10
Re: Warped discs
Potentially yeah, guessing when they got changed last time formula 1 didn't fit them correctly. There is still a slight bind now but it's practically nothing at all, I took it for a drive and checked the disc temperature when I got back and they was luke warm on both sides, where as before the passenger side was hot, I'm hoping the problem is sorted now :/
Old 24-10-2013   #11
Moderator
ChrisUK's Avatar
Trader Rating: 1
ChrisUK has donated!
Bartender Champion, Wood Firing Champion
Re: Warped discs
Could be sticky calipers. Just had to change one one the back mine.
Jack car up at the front the wheels should spin easily.
The fact my local euro car parts keep a good stock tells me something
ChrisUK is offline Reply With Quote Quote
Old 24-10-2013   #12
Re: Warped discs
Yeah it does now, if I spin it with average force it will spin two or three and then stop, when it was binding it was barely 1 spin! I think there should be some amount if bind as they haven't been bedded in yet, I've literally done 1 mile on them so to have a very small amount of binding should be ok.
Old 25-10-2013   #13
where as before the passenger side was hot :/
Doh! Why didn't ya say.
Old 25-10-2013   #14
Re: Warped discs
Quote Originally Posted by jameshobiecat View Post
Sorry it's my fault for the way I worded it, when my passenger side was hot It was with my new set of discs not my old ones.
I had to take it apart again after fitting the new pair and clean the passenger side down, and take the shim cover off to stop it binding. Not sure if the set of pads was slightly bigger or what but it's not binding now.
I'm not sure if they was binding on my old discs to be honest I never really checked as it was done by a garage so was just hoping it was done properly. Cheers for all your feedback guys!
Thread Tools
(T) warped discs? boddahchris Grande Punto 1 14-09-2012 21:36
(T) Discs warped - change pads too 3corsameal Bravo / Brava 7 19-01-2009 23:29
(T) What causes warped discs? dan-the-man Stilo 18 11-05-2006 21:35
(T) Warped discs Drinu Uno 9 31-03-2006 14:28
