| Thread Tools |
![]() | #1 | ||
Posts: 59 Thanks: 0 Trader Rating: 0 ![]() | T-Jet engine Hey guys, I don't know if this has been asked before but is the T-jet engine in the Bravo the exact same as the one in the Punto, gear box as well?
![]() | #2 |
Posts: 2,400 Thanks: 83 Trader Rating: 0 ![]() | Re: T-Jet engine It depends, the 150 t-jet in the bravo has a 6 speed box. You will need the 120 version from the bravo for the 5 speed. I cant guarantee that the mounts are the same although they should be.
__________________ My Grande Punto T-Jet Daisy ![]() |
![]() | #3 | ||
Posts: 59 Thanks: 0 Trader Rating: 0 ![]() | Re: T-Jet engine Yeh but if i buy a Bravo engine with the gear box do you think it should be a straight swap into my GP?
![]() | #4 |
Posts: 92 Thanks: 4 Trader Rating: 0 ![]() | Re: T-Jet engine M32 gearbox (6 speed) I would presume
__________________ Drives: S2 White Grande Punto Sporting 120 T-Jet S1 Red Grande Punto Sporting 95 Track Project ![]() |
![]() | #5 | ||
Posts: 8 Thanks: 0 Trader Rating: 0 ![]() | Re: T-Jet engine I got the 1.4 t-jet bravo 120 and it has the 6speed box. Dunno if it's the same as a punto tho...
![]() | #6 | ||
Posts: 59 Thanks: 0 Trader Rating: 0 ![]() | Re: T-Jet engine Well i know that the Bravo and Punto both have 6 speed T-Jet engines and I am wondering if they are both the same because if they are then I am going to buy the Bravo one and put it in my punto as I cant seem to find any punto's breaking online but I can find loads of Bravo's.
![]() | #7 | ||
Posts: 83 Thanks: 1 Trader Rating: 0 ![]() | Re: T-Jet engine Should be the same, only gear selectors can be different
![]() | #8 | ||
Posts: 59 Thanks: 0 Trader Rating: 0 ![]() | Re: T-Jet engine Thats what I was thinking, logic says that they would be the same seeing as though they are both outputting 120bhp and they are both 6 speed also why would Fiat bother making a different engine?
![]() | #9 |
Posts: 2,400 Thanks: 83 Trader Rating: 0 ![]() | Re: T-Jet engine The t-jet in the punto is a 5 speed not a 6... although the 1.9m jet has a 6 speed so it will fit, not sure of mounts though. And the bravo has a different intake routing as well. So you would have to get a punto t jet air box.
![]() | #10 | ||
Posts: 59 Thanks: 0 Trader Rating: 0 ![]() | Re: T-Jet engine I have seen 6 speed T-jet Punto's online though?
![]() | #11 |
Posts: 2,400 Thanks: 83 Trader Rating: 0 ![]() | Re: T-Jet engine Lol, u sure? They have either been converted to a 6 speed or are advertised wrong. They didn't do a 6 speed in the punto t-jet, although it would really benefit one.
__________________ My Grande Punto T-Jet Daisy ![]() Last edited by Sweex; 26-09-2013 at 16:05. |
![]() | #12 | ||
Posts: 1,945 Thanks: 100 Trader Rating: 0 ![]() | The 155bhp abarth puntos have a t-jet engine and six speed box but all of the 120 t-jets are only five speed. Could you not buy the engine only and use the original gearbox?
![]() | #13 |
![]() | #14 | ||
Posts: 1,945 Thanks: 100 Trader Rating: 0 ![]() | That wasn't aimed at you sweex, it was for the OPs information only. I also assumed the op has a t-jet to start (with a knackered engine) with but can't see the signature on android so I'm not too sure. If the op is suggesting an engine up-grade then the standard advice is to forget it and buy a proper t-jet as otherwise it will cost a fortune to modify and insure.
![]() | #15 | ||
Posts: 3,094 Thanks: 84 Trader Rating: 0 ![]() | Re: T-Jet engine Can you use GP tjet clutch on the m32? The 150t system has a dmf /runaway
Thread Tools | |
about 1.4T-JET engine | Nina | Lets Talk FIAT | 11 | 04-12-2016 00:19 |
T-jet engine | yurig | Tuning | 3 | 02-09-2012 11:33 |
![]() | PhillRC | Grande Punto | 6 | 29-01-2012 13:21 |
![]() | Mawso91 | Grande Punto | 5 | 11-05-2011 23:04 |
