Rob93 My Other Car Is A V8! Parked in the garage Joined Aug 12, 2011 Messages 491 Points 168 Location Farnham, Surrey Sep 25, 2013 #1 Hi guys, Does the turbo on the EsseEsse differ from the one on the basic Abarth 155hp?
middo85 Patron member Parked in the garage Joined Feb 20, 2009 Messages 855 Points 163 Sep 25, 2013 #2 No, the standard abarth uses the IHI VL36 whereas the esseesse uses a larger garrett unit. They arent a straight swap either, quite a bit of piping is different also
G GYoung87 Member Parked in the garage Joined May 21, 2011 Messages 484 Points 101 Location Bury Sep 25, 2013 #3 Esseesse uses Garrett GT1446
OP OP Rob93 My Other Car Is A V8! Parked in the garage Joined Aug 12, 2011 Messages 491 Points 168 Location Farnham, Surrey Sep 27, 2013 #4 middo85 said: No, the standard abarth uses the IHI VL36 whereas the esseesse uses a larger garrett unit. They arent a straight swap either, quite a bit of piping is different also Click to expand... So it is going to require a bit of homework to replace/fit the standard T-Jet 120's turbo with the EsseEsse's one?
middo85 Patron member Parked in the garage Joined Feb 20, 2009 Messages 855 Points 163 Sep 27, 2013 #5 Rob93 said: So it is going to require a bit of homework to replace/fit the standard T-Jet 120's turbo with the EsseEsse's one? Click to expand... Yes, the oil and coolant feeds are different and the esseesse has different injectors and boost sensors. Unless you can get hold of a full esseesse kit id say its not really worth the hassle unless you are going for big power. A VL36 with an uprated intercooler, induction and a remap will see you at esseesse power
OP OP Rob93 My Other Car Is A V8! Parked in the garage Joined Aug 12, 2011 Messages 491 Points 168 Location Farnham, Surrey Sep 27, 2013 #6 middo85 said: A VL36 with an uprated intercooler, induction and a remap will see you at esseesse power Click to expand... Was thinking of trying for 200. But maybe just VL36 with Forge IC, remap and Abarth injectors should do the trick Already have a decat & Forge induction Thank you for your time mate
