im Axle Specialists
Thread Tools
Old 23-09-2013   #1
mattmuirhead93 has donated!
Lowering - where to start
Ok so for a while I was happy with my car - then someone decided to point out the gap that makes the GP look like it's standing on it's tip toes. Ever since I've been toying with the idea to lower it.
Few problems, I live on a hill and I park on a hill - a steep one! What's the minimum I can lower it by to get rid of the gap and make it look good but not to make it too close to the ground that I leave a blue streak of paint on the drive? Also don't want to make the ride any less comfortable.
My second problem is I have no knowledge what so ever of lowering. What do I need to get? (Recommendations very welcome!) can I do it myself or take it to a garage? And the biggest question how much is it going to cost me?
Thanks in advance for your help! Click image for larger version
Name:	ImageUploadedByFIAT Forum1379960926.709112.jpg
Matt Muirhead - F9 MRM
My Instagram
mattmuirhead93 is offline Reply With Quote Quote
Old 23-09-2013   #2
:) Anthony & Sheena (:
mr and mrs tjet's Avatar
mr and mrs tjet has donated!
Re: Lowering - where to start
Quote Originally Posted by mattmuirhead93 View Post
Thanks in advance for your help! Attachment 124483
Eibach sportlines are the most common on here, we have them dont really make much difference in the ride quality
Likes SJB1985 liked this post
VrrrrooooooommmmmMM!
mr and mrs tjet is offline Reply With Quote Quote
Old 23-09-2013   #3
staffordmike has donated!
First of all get someone to watch as you pull on to your drive, or better still watch for yourself as a friend or relative pulls on to it. Keep looking to see how much or how little clearance there is between the bottom of your car and the drive. Bear in mind that it may not be the sills that are lowest point on the car, it could be the exhaust or something else. Once you know how much room you've got to play with you can consider how much you can lower the suspension.
staffordmike is offline Reply With Quote Quote
Old 23-09-2013   #4
Grande Punto Fanatic
SJB1985's Avatar
SJB1985 has donated!
Get some Eibach Sportlines on your GP mate everyone on here that hasn't got coilovers has eibach sportlines/prokit new they will cost you about £140.00 to £160.00 new or as little as £60 to £80 used. They will lower your car by 45mm at the front and 30mm at the rear pro kit is 30mm/30mm.
In terms of getting them fitted I personally wouldn't attempt this due to safety issues, correct tools etc. I paid £80.00 to have mine fitted and haven't regretted it once!
Regards
Stephen
Likes Jordan92, mr and mrs tjet liked this post
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.”
Instagram: 1985SJB
SJB1985 is offline Reply With Quote Quote
Old 24-09-2013   #5
MAAAAAAD!!
Jordan92's Avatar
Jordan92 has donated!
Yeah that.
Jordan92 is offline Reply With Quote Quote
Old 24-09-2013   #6
Thanks everyone for the advice, in terms of buying used compared to new is there going to be much difference in performance? i.e. are the used ones likely to give a worse ride?
My Instagram
Old 25-09-2013   #7
Mjet220 has donated!
Rears are a piss ball, fronts the old springs jesus there squashed down, new ones slotted right in no issues under no tension
Mjet220 is offline Reply With Quote Quote
Old 25-09-2013   #8
MAAAAAAD!!
Jordan92's Avatar
No probably not unless they have lost there coating. Eibach are obviously a very well known an premium spring production company so all there producs are "no corners cut" quality and made to last. if you get them off someone on here chances are they will be fine but it is like buying anything 2nd hand just check before you buy. iv had mine on for nearly a year and i had the wheel off the other day and wipped the springs and they look brand new still
Jordan.
Old 25-09-2013   #9
Quote Originally Posted by SJB1985 View Post
Regards
Stephen
What safety issues are there mate?
ive changed my top mounts for which the springs obviously have to be removed and the most dangerous part was not straining my back picking up the trolley jack lol. Shocks should be simple to remove, then spring compressors on, springs off, new springs on, shocks back in, job done .
Current: 56 FIAT Grande Punto 1.9 MJET Exotica Red - Projector headlights, hid bulbs, pressed metal plates, updated red badges, gloss black grille, more to follow
Formally: 03 FIAT Stilo 1.9 JTD Dynamic 115 Broom Yellow - Abarth Side Skirts, Black Chrome Blades, Lowered 30mm, Badgeless Mesh Grille
Rackham115 is offline Reply With Quote Quote
Old 25-09-2013   #10
Oh Lord! I bought a Fiat!
james44422's Avatar
Trader Rating: 1
james44422 has donated!
I've heard horror stories of springs flying off and hitting and even impaling people
https://twitter.com/J44422
james44422 is offline Reply With Quote Quote
Old 25-09-2013   #11
SJB1985's Avatar
Quote Originally Posted by Rackham115 View Post
As said above by @james44422 I have heard some horror stories of springs flying off etc and also not being corerctly fitted correctly and causing problems etc. I always feel that it is best to err on the side of caution mate. I hear what you say and you obviously have the correct tools and understanding of how the job is to be done
Regards
Stephen
Instagram: 1985SJB
Old 25-09-2013   #12
Anti-lag ftw!
Reuuk's Avatar
Trader Rating: 1
Reuuk is part of the official FF Events Team :)
Reuuk has donated!
Babe Jump Champion, Sofa Longjump Champion, Space Explorer Champion
there is also the issue when tightening or loosening everything up that you wack the windscreen with your tools and crack it... @Andy Monty
Likes dombooth liked this post
follow me on Instagram: @reuuk
Mini Cooper S & Abarth 500
Reuuk is offline Reply With Quote Quote
Old 25-09-2013   #13
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Quote Originally Posted by Reuuk View Post
Shhhhhhhhhhhhhhh
Op take a look at this
https://www.fiatforum.com/grande-pun...placement.html
Massive gash
Just a little touch up
Old 26-09-2013   #14
Moderator
dombooth is part of the official FF Events Team :)
dombooth has donated!
dombooth is an honorary friend of the forum :)
DiffSpotter 3 - Rooms Champion
Pmsl.
Dom
Current Car: FIAT Bravo 150T Sport
And the mighty Fiat 126!
dombooth is offline Reply With Quote Quote
Old 26-09-2013   #15
Regards
Stephen
Ah right i see. Yeah a highly compressed spring is not something to be messed with.
Thread Tools
(T) Cold start/Warm start.... fish6634 Punto (Mk2/2b) 1 23-08-2012 20:18
(T) Car won't start unless you bump start it? benny279 Punto (Mk2/2b) 11 10-06-2012 18:04
(T) replacement start key with start/stop button D1Gi Panda 2 30-05-2011 14:54
(T) Stilio 1.9JTD 02 Wont Start, Unless "engine start" is Used CraigLL Stilo 21 24-06-2010 21:41
(T) Cant Start Wont Start GhostWKD Cinquecento / Seicento 31 25-10-2005 00:16
