Hi Everyone,
I'm newly registered but have been reading all the threads that I can find on Immobiliser issues, so please do not shoot me down as I'm asking for some further help.
My sons Grande Punto 1.2 8V 56 plate 75K miles has suddenly stopped running, prior to this it ran perfectly with no problems at all.
Immobiliser light on permanantly, ABS light intermittant, temp guage needle travels H-C etc, etc.
To date we have checked all the recommended earth cables (replaced main one battery - chassis - gbx) changed the battery for a new unit. Replaced the ECU, body computer (glovebox fusebox unit) and ignition barrel + pick up ring (the ecu, bc & lock set were from a similar aged scrapped GP) The engine compartment fuse box has been removed sprayed with water dispersant and dried out thoroughly (it was dry to start with but we are trying to cover all bases !!)
However the immobiliser light still remains on and the starter motor does not operate. Do we need to get the immobiliser reset by FIAT? (I thought that changing the coded set would avoid this !!)
Any further hints or direction would be appreciated :bang:
