General HELP Window motor working but window not moving!
Just fitted a window deflector and after putting the window up, it was a squeeze then it stopped moving. The window stopped and it sounded like parts from the windows mechanism fell apart. Like bolts in a washing machine. Currently tapped the window over going to look at it soon.
Took the door card off, the pulley system has slipped off it's wheel. Should be easy to fix but for now I've just jammed the window in place. It's solid and water tight.
