I have noticed over the last couple of days that my clutch has felt a bit funny.
Funny in a way that when i have been changing gear, the pedal is vibrating, not violently but its noticeable. And when pulling away the same sensation through the pedal.
The clutch also whines when the pedal is pressed down but only when cold (suggesting thrust bearing)?
However I was sat in traffic with my foot on the clutch in 1st gear (not biting) and all of a sudden the clutch pedal started vibrating and the car was trying to pull away and then stalled but my foot was still pressed down on the clutch. (Luckily i had the handbrake on) After it stalled it was stuck in gear with the clutch also stuck fully to the floor! I managed to pull the clutch up and get it out of gear and drive to my destination. But it did it again when i stopped as i wanted to see if it was a one off, which it wasn't.
I dont know a lot about clutches so does anyone have any ideas of what this could be?!
I know it is not going to be cheap.
Thanks in advance,
Luke.
Thanks in advance,
Luke.
