Technical Hill Holder / M25 Speed Cameras
Hertfordshire
Hi Guys,
Hill holder light came on 2 weeks ago.
Filled tyres up to 34psi, front to 36psi... BAM... hill holder unavailable
Says "ASR disconnected' then says 'ASR connected" on my dash display...
2nd thing, bit off the track, I got flashed by Gantry on weekend 11ish at night doing 93mph.
Any idea if I'll get a ticket? Driven that stretch of road loads before but never been flashed.
Seen online on loads of forums that no one has got tickets...
Shed some light lads.
93mph on the Speedo = 86mph ish in real life so probably above the threshold for prosecution I'm afraid.
There are far more gantry camera boxes than actual cameras, most are empty but they move the cameras around so you can't be sure which. Sounds like you've been getting lucky up until now, but you finally came across a full box. It was bound to happen.
Does anyone know if those cameras have gone digital yet? If not there is a good chance the camera that flashed you will have been out of film; the film can run out in a matter of minutes.
As said above, if you don't get a nip in 14 days then you are home free.
They can be turned on and off as required apparently. And I am told they are set to +10%+2mph - so for 70, they're set to trigger at 80
10% of 70 = 7
+ 2 = 79
Speed at which you can be pinged = 80
That was specifically for the M25 cameras info from a Roads Policing Officer
There are lots of myths and misunderstandings about cameras. The 10%+2 rule is a guideline, as are most of the other things published. A few years back some forces had a zero tolerance approach.
If the detection rate is too much for the Central Ticket Office to handle, they may increase the enforcement threshold.
As for assuming that others have been flashed and got away with it, maybe it was just because they weren't in use.
The 14 day rule for the NIP only applies to the registered keeper, not all drivers e.g lease vehicles, hire cars, reg in parents name etc. Others drivers may have to wait for the time it takes for the keeper to confirm who was driving.
Was the gantry displaying anything at the time? Usual policy in England is not to enforce the national speed limit using the cameras.
Lol - no worries, take it you missed the %? Easy done!!
Talking of speed cameras - word from my Copper Friend - the average cameras covering the A23 (40mph) roadworks are now active!
HELLO ALL!!!!
Gantry camera flashed me but no speed showing on gantries before it.
So no variable speed limit.
FEEDBACK
NO TICKET THROUGH THE DOOR...
...apparently on m25 the average speed cameras only do you whilst there is a variable speed limit. so when i got flashed, it was ok as no speed shown on gantry camera. done the trip a couple of times since, not risked it though :cool:
my friend said he did 70mph average by heathrow and didnt get done by average speed camera
forums online saying that no one has been fined for last 4 years on m25 by any camera... dont want to risk it though :p
looks like i got away this time.
Lucky lucky then. Personally, i don't see why risk it anyway. The amount of times i've been caused trouble by some kn**jock doing a tonne is unreal.
How can it have caused you trouble unless you were sitting in the wrong lane and had to move over?
I'm no lane hogger. More general to people speeding in general, not limited to dual lane roads ect. Also i mean when you look in your mirror - clear. Indicate, check again - clear. Begin to move over - kn*bhead!!!
:D I wouldn't complain on a German Autobahn, as you come to expect it. The kn*bjocks that speed and then undertake even in rush hour are even worse though...
Do not confuse "average" speed cameras with normal speed cameras.
The ones on the gantries measure your speed at that time, but as said, these are usually only switched on when variable limits are set. I believe that the M25 ones are now all digital and linked to an ANPR system and teh DVLA database. If caught, the system reads the plate, prints a letter to the registered keeper and an automated folding system puts it into an envelope, seals and posts it, without human intervention. People only get involved if the ANPR database flags it, or it cannot read it properly. In the case of one of these, it alerts the police force immediately, so that the car can be stopped if patrols are nearby/available.
Average speed cameras are the yellow ones in roadworks. They use ANPR technology to record you passing the first camera, then when it reads it again, it calculates your average speed between the cameras. Braking for these is futile, as well as dangerous.
Dont have a clue how them average speed check cams work, i drive at 70mph through them others 80-90 will they get tickets
I'm not sure about when there is no restriction in place.
When there is a restriction other than 70 (say 50 due to an accident or congestion) then they are definitely active. If your average speed through the cameras is greater than 50 you will get a ticket, I can confirm this :bang: (there is the rumour about 10% lenience but i'm not sure how true that is)
But when it is normal 70mph i'm not sure if they are active or not. But best to be safe and stick to 70 (y)
