Technical Light buzzer
shazk85
Is there or isn't possible to put a buzzer on that when I open my doors and have my lights on it buzzes???!!
I have an 08 model and so far only left lights on for short time but don't think be long before do it over night and have flat battery as I forget lights on as doesn't bing to remind me when I get out? X
Oh don't no hadn't thought of that I just assumed they would stay on ill have a look at that one and get back to u xxx
The lights should turn off when you turn the ignition off.. Unless you turn the lights off and back on to activate parking lights, or pull the main beam flasher to set the follow me home time increases in 30 second intervals per pull...
Start car turn on lights then stop car lights should go off....
If you find they randomly stay on check the engine bay fuse box is dry inside and the multi plugs at the bottom of it.....
Make sure the lid is fitted correctly too
A great fiat quirk! I've not had a car that did this before but its so usefull. I tend to leave my sidelights on all the time now (as sort of drls).
Leave my sidelights on all the time and just go up and back to dipped when necessary. So far, it hasn't drained the battery so I assume they're off overnight!
Thanks very much yes they turn off when key removed and thanks regarding parking lights that was going to be next question x who needs a thick instruction manual lol x
