General Changing tie rods
Newcastle
Hi ff!
I've tried to search but I'm on my phone and the box comes up and disappears :mad: can't find anything on google either..
Anyway, since buying my car it's had a faint clunk going over bumps which seems to be both sides but more on the left. MOTd it last month and it had an advisory for the inner steering rack joint which I assume is the inner tie rod (the bloke that tested it wasn't around when I picked the car up)
Anyway.. How are they to do? Any special tools needed .. Is it one of those jobs you might aswell pay a garage with a nice ramp to sort?
Cheers!
Rang the garage and he remembered the very low black punto lol! Inner tie rods as I thought.. So back to the original Q.. Has anyone changed one? Looking at part it doesn't look like it would cause much drama.
Easy enough, Just remember how many turns / mark it up so it goes back on relatively near to where It was for tracking purposes lol.
excellent so apart from the usual it's no majour drag? (i'm on about the inner tie rod mind) some of the threads on french tat i was reading saying you need all sorts of special gizmos.
If its your inner track rod you just need to take outer tie rod of count the turns you'll need mole grips to take inner one of remove dust cover first then place new rod next to old one and check length then put new one on and cable tie dust cover easy job good luck
excellent cheers, from what i can work out the cars that need special tools are ones that need the ball joint seperating in order to fit.
the part i ordered is the same on as in your link and is all one unit, cheers for the reply (y)
Well 2 years on and I finally changed it, no chance was it coming off with mole grips so I stuck some weld on the ball joint to get it off with a spanner.
Sorted the clunk.. Finally!
