P peterkuli New member Joined May 25, 2013 Messages 2 Points 1 May 25, 2013 #1 I think my MAP sensor is broken. I've called a part distributor and they told me that there are 2 kinds of MAP sensors. Does anyone know how I can determine which one I need?
Andy Monty Moderator Staff member Parked in the garage Written 10+ guides Joined Apr 30, 2006 Messages 16,904 Points 3,632 Location East Yorkshire May 26, 2013 #2 you should be able to get the part number off the old one... the only one i have come across is this type https://www.fiatforum.com/grande-punto-guides/227405-1-2-1-4-map-sensor-replacement.html http://www.ebay.co.uk/itm/MAP-Manif...M&hash=item3ca3150a22&clk_rvr_id=484032800065 however some use this type http://www.ebay.co.uk/itm/Fiat-Gran...M&fits=Model:Grande+Punto&hash=item35c4d6cd2c This post contains affiliate links which may earn a commission at no additional cost to you.
OP OP P peterkuli New member Joined May 25, 2013 Messages 2 Points 1 May 27, 2013 #3 Thanks! First one of the tutorial you mention is the one I've got, so I asume this is the right one.
Andy Monty Moderator Staff member Parked in the garage Written 10+ guides Joined Apr 30, 2006 Messages 16,904 Points 3,632 Location East Yorkshire May 27, 2013 #4 peterkuli said: Thanks! First one of the tutorial you mention is the one I've got, so I asume this is the right one. Click to expand... if you remove it you should be able to read the bosch part number which any good car parts shop should be able to match the part up
