![]() | #16 | ||
Posts: 27,231 Thanks: 1050 Trader Rating: 0 ![]() | Re: Grande punto 1.2 active boot leak....... Has the motor been off recently? Only issue Ive had before is water ingress to the wiper spindle.. jamming the motor ![]()
![]() | #17 | ||
Posts: 55 Thanks: 4 Trader Rating: 0 ![]() | Re: Grande punto 1.2 active boot leak....... The spindle rusting is common on lots of cars using this motor. You can bring it back to life by putting it all in a bath of oil. See this... https://www.alfaowner.com/threads/so...seized.862546/
![]() | #18 | ||
Posts: 27,231 Thanks: 1050 Trader Rating: 0 ![]() | The spindle rusting is common on lots of cars using this motor. You can bring it back to life by putting it all in a bath of oil. See this... https://www.alfaowner.com/threads/so...seized.862546/ ![]() https://www.fiatforum.com/marea/3315...ml#post4368561 @OldEngineer How old was that Alfa?
![]() | #19 | ||
Posts: 55 Thanks: 4 Trader Rating: 0 ![]() | Re: Grande punto 1.2 active boot leak....... It's a 2009 with the same wiper as the Grande Punto
![]() | #20 | ||
Posts: 61 Thanks: 1 Trader Rating: 0 ![]() | Re: Grande punto 1.2 active boot leak....... Hi, I know this is an old post.......... I had a boot leak which was hard to identify, came thro' inside panels badly. Turns out it was the gutter joint, took rubber out and used a Good sealer on about 6" of it. On first analysis it did appear to be light cluster. It used to pour in when rained!! Not any more.
![]() | #21 | ||
Posts: 5 Thanks: 0 Trader Rating: 0 ![]() | Ok... where to begin. Its alot but the boot is 100% water tight. The wiper leak. After I siliconed the outside ring thinking that was the leak, when I done my next water test I found it made 0% progress at stopping the leak and I was not at all correct about the water coming from the rubber. It was 100% coming through the hole in the rear window for the motor but not from anywhere I could see. So as you can see from my new photos and alot of trail and error I ended silconing the entire hole up and some of the bottom rear window as it was the only way I could get my finger to make it water tight. I stopped the water coming in through the motor hole BUT during another water test it was still coming in somewhere else aswel!! The only place now I could think of was the actual rear window seal. So decided to silcon the rear window seal outside all the way along. I left the hose gushing over my rear window and sat inside the boot for a good 15 minutes and with 100% success I didnt see a single drop of water. Now the boot lock was safe from anymore water drops i brought some wd40 contact cleaner from screwfix and with a kitchen sink bristle brush I cleaned up the connections refitted the connection and screwed the lock back in and again another success the boot lock was in full working order again! The side leaks. Oringally I thought water was coming in from poor seals around the lights on both sides after silconing them with 0% effectiveness water was still coming in at the same rate. More trial and error i got my kitchen sink bristle brush and decided to remove the yellow sealent over the welding at the top of the boot. That's when I saw some huge cracks in the welding!!! (Again seen in the photos) some more silicon to seal them up on both sides and now the side leaks are sealed too! I hope this helps anyone in the future from going through the pain, disappointment, time and effort I had to go to as I tried alot of ways I've not even mentioned here to seal those leaks. Never give up
![]() | #22 | ||
Posts: 3,166 Thanks: 165 Trader Rating: 0 ![]() | Re: Grande punto 1.2 active boot leak....... Those cracks look to be in the seam sealent that's used to make the joint's waterproof The welding itself should be under that and much smaller That's far too thick to be a welded seam
![]() | #23 | ||
Posts: 61 Thanks: 1 Trader Rating: 0 ![]() | Re: Grande punto 1.2 active boot leak....... Hi, That factory sealer has dried out and non functional. If you scrape it all off and back along the joint to where it feels firmer, you can reseal with a GOOD sealer / mastic. I had to do this and it worked a treat. Take your time cleaning / clearing and you will have a GOOD result , NO WATER in your boot tray !
![]() | #24 | ||
Posts: 5 Thanks: 0 Trader Rating: 0 ![]() | Re: Grande punto 1.2 active boot leak....... I'm yet to have much rain since I've sealed it but will keep an eye on it and keep it all posted, naturally I'm always squeezed for time and budget
![]() | tolittlekingdom | Grande Punto | 141 | 03-01-2013 11:14 |
