FIAT Auto Specialist Team
Old 03-04-2013   #1
Driver side electric window switch
Hope somebody can help.
I'm having a problem with the drivers electric window on my 06 grande punto.
The switch doesn't work- window is thankfully stuck in up position. The mirror and passenger window controls work fine.
I taken a loon at the body to door loom and it looks fine, I have also cleaned up the actual switch contacts with contact spray but still nothing.
The switch lights up but when I try the switch the light goes off then appears back a few seconds later.
Anyone gave any ideas?
Could it be a fuse?
Or do I need a new switch unit?
Loathed to take it in to a dealer of I can fix it myself.
Paul
Pea6969 is offline Reply With Quote Quote
Old 03-04-2013   #2
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Re: Driver side electric window switch
Sounds like it may possibly be the switch unit, might be worth a punt in a used replacement from eBay etc.
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Qubo Dynamic Dualogic WAV & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 03-04-2013   #3
What makes you think that? Is it because the light is going off and on?
Old 03-04-2013   #4
Trader Rating: 2
Quote Originally Posted by Pea6969 View Post
Indeed, it doesn't sound like it functioning properly, and you've checked everything else.
Old 03-04-2013   #5
I took the switch mech out and put it back together but like you say it could be the actual circuit board that's faulty.
I will prob try eBay lithe you suggest unless anybody else cones up with any theories, thanks.
Old 05-04-2013   #6
JimbbobW1977 has donated!
My wiring looked fined intil i took the whole loom out and removed the rubber sleeve that connects from the door to the car body. 5 wires were split in half.
JimbbobW1977 is offline Reply With Quote Quote
Old 06-04-2013   #7
How did you rectify that? Dealer job?
Old 08-05-2013   #8
I soldered them back together and heat shrink wrapped them then taped them.
Everything worked again after.
It was either spend £12 on a soldering iron (the dealer told me how to fix it and even gave me the heat shrink for free) as opposed to paying over £200 for a new wiring loom.
Likes Punto.Power liked this post
(T) Help!!! Electric driver window fault!! Becks1277 Grande Punto 4 01-02-2013 22:49
(T) driver's electric window Colin. Punto (Mk2/2b) 5 14-04-2009 22:49
(T) Driver side electric window Olof Larsson Bravo 10 08-04-2009 16:09
(G) Ducato Van Driver’s Side Electric Window Problem rupz Ducato 0 02-09-2007 20:07
