mmalik1970
- Feb 13, 2013
- 2
- 1
The dipped headlights on my Fiat GP MJ 1.3 began flickering on and off before Christmas, then decided too stay on all the time, apart from when you take the keys out. As I leave home in the dark and come back when it is dark, thought I would wait to investigate.
The stalk works for going between dipped and full, but won't turn off, so not sure if it is this that is causing the problem.
Before I folk out hundreds in getting the stalk replaced, want to take out of the equation any electrical issues.
Would anyone be able to provide wiring diagram, including the relays used, as I am sure that the issue is that the relay is the cause, but not sure which one to test.
Another oddity is that the left dipped headlight is no longer working after I had to jump start the car a couple of days ago, but I get no warning on the dashboard about this, but the side light comes and goes, and I do get a warning light about this.
Hope someone can help.
