![]() | #1 | ||
Posts: 18 Thanks: 0 Trader Rating: 0 ![]() | How to bleed the clutch on GP 1.9 Hi Wondered if anyone can help me.... Just had my gearbox out of my GP to have a bearing replaced. Nearly all back together now just need to bleed the clutch. Does anyone know how your meant to do this? I have a rough idea. Did have a look for a guide but can't seem to find anything ![]() Thanks Lia x
![]() | #2 |
Posts: 16,588 Thanks: 912 Trader Rating: 0 ![]() | Re: How to bleed the clutch on GP 1.9 By the looks of it - the release bearing is built into the gearbox and linked by a pipe Bit like the ford fiesta's Anyway There should be a bleed nipple near the intake pipe on the gearbox locate where that is - unfortuantly i dont have a GP so cant advise But either with a pressure bleeder or a Vacuum bleeder it'll be a matter of minutes todo if you have neither of the above, next is the 2man method 1 on the nipple - 1 on the clutch pedal With abit of pipe on the nipple and spare fluid ready Engine bay man is in control He shouts down - Clutch man puts pedal down and shouts down - open bleed nipple little bit of air and fluid will spit out - close the nipple - engine bay man shouts up - clutch man moves pedal up and shouts up when he's done it Repeat the up / down process till the fluid is completly bubble free. If the pedal feels soft then hits hard, air is still trapped somewhere This is why a vacuum bleeder or pressure bleeder is great because it forces it out with ease ![]() Ziggy
__________________ |
![]() | #3 | ||
Posts: 121 Thanks: 3 Trader Rating: 0 ![]() | Re: How to bleed the clutch on GP 1.9 Hi there , try using a easy bleed ..... Best way to bleed clutches and brakes ![]()
![]() | #4 | ||
Posts: 18 Thanks: 0 Trader Rating: 0 ![]() | Re: How to bleed the clutch on GP 1.9 Thanks ![]() ![]()
![]() | nikkiy9 | Stilo | 16 | 06-02-2012 19:12 |
![]() | david295 | Punto (Mk2/2b) | 2 | 09-10-2010 22:42 |
![]() | gillian conroy | Punto (Mk2/2b) | 0 | 26-04-2009 16:31 |
![]() | Stilo170 | Stilo | 2 | 22-03-2008 21:09 |
![]() | sean2079 | Punto (Mk2/2b) | 13 | 07-09-2007 09:02 |
