Thread Tools
Old 07-02-2013   #1
South Africa
gp 2007 1.4 8valve not starting
Hi all, my gp is not starting. Had a accident from front, inertia switch was tripped, if I pour petrol down the throttlebody it runs, my fuelpump is working, engine management light is on, no response from acc pedal, I'm in south africa, I bought the car like that very cheap, the gp is in a very good condition, please help me
samuel j vd merwe is offline Reply With Quote Quote
Old 11-02-2013   #2
Re: gp 2007 1.4 8valve not starting
We need a code from the EML
keat63 is offline Reply With Quote Quote
Old 11-02-2013   #3
South Africa
There is no codes displaying, I don't know a lot about gp, I would like to know more, all that I know is what I read on this forom, how do I get that code?
Old 11-02-2013   #4
Moderator
Andy Monty's Avatar
Andy Monty has donated!
You need access to an obd 2 code reader
Is all the wiring to the accelerator and throttle body intact any damage to the pedals (they can break in a crash they are designed to to protect your feet)
Massive gash
Just a little touch up
Old 12-02-2013   #5
South Africa
No damage, the car was in a small accident, airbags didn't even deploy, it means I must get someone with a code reader, the car only idles but after about 10 times trying to start, if I turn the key the car starts and dies, then would only idle after 10 trys, acc makes nearly no differens, idles at 1200rpm, if I touch the pedal very little it goes up to 1300 rpm and goes down to 1000 rpm and then no respons from pedal
Old 12-02-2013   #6
Moderator
Andy Monty's Avatar
have a read of this
https://www.fiatforum.com/grande-pun...wont-idle.html
look at my posts and the other mod T13445 (or what ever number it is)
Old 12-02-2013   #7
South Africa
Thanx for helping me out Andy, I have done it all, the tb is clean as n nun, I have taken it off and clean it, if I switch the ign on the flap vibrates only, it is not opening a lot, only about a millimeter, if the car decides to starts it is only idling, helping the flap open only makes a noise, not revving up, when I pour a little bit of petrol in and I open the flap it revs up to about 5000rpm and dies again, its a complicated car for me, I'm a diesel technition and been working on all my petrol cars for many years, but this one is beating me
Old 12-02-2013   #8
South Africa
Some one said once that u got to earn a fiat before owning one, I believe it now, my other car is a uno 1993 1100 and going strong and no breakdowns with it, but my gp will make me pull out my hair and I haven't driven it at all, its such a nice car
Old 12-02-2013   #9
Moderator
Andy Monty's Avatar
Have you tried taking the battery off and leaving it for an hour to reset the ecu?
then try a relearn if that doesn't work...
look at the accelerator peddle and throttle wiring?
Not seen anyone have this issue before
Is the Fuel reset supplying power to the fuel pump?
no air lock in the fuel lines?
(total stabs in the dark)
Massive gash
Old 12-02-2013   #10
1.4 16v Nissan Note Visia
Magic Johnson's Avatar
Magic Johnson has donated!
Erm...your car was in an accident, it could have damaged ANYTHING in the engine.
Has your Uno been in an accident? If not why are you comparing it?
Magic Johnson is offline Reply With Quote Quote
Old 12-02-2013   #11
Moderator
Andy Monty's Avatar
Quote Originally Posted by Magic Johnson View Post
Sounds like he bought the car cheap accident damaged rather than crashed it himself
The inertia switch can be triggered by a violet jolt such as hitting a pothole
most of the time in a minor its only panel damage and bits just need bashing straight Sounds like he is a mechanic of some sorts Lorry mechanic samuel?
If you have access to a laptop computer or android based smart phone can you get something like this Cheaply over in Africa?:
http://www.ebay.co.uk/itm/ELM327-Any...item4abb8950bc
or
http://www.ebay.co.uk/itm/Android-To...item19c9ec554f
Massive gash
Old 13-02-2013   #12
South Africa
Yes, I'm a mechanic on lorrys, my uno has done over 400000 km and I'm making a comparison only because its also fiat, I love my uno and bought the gp to upgrade and the gp was in a front accident, only panel damage and its in a good condition, I'm typing this with a blackberry cellphone, I want to say thanx so far, I have done all the checks so far and found my bottom exhaust sensor to look suspect, bent upwards on the casing where the wires goes in, caramic is cracked, maybe I must try that first, wil the sensor cause all this, is there a way I can check it with a multimeter and what is the values on the 4 wires?
Old 13-02-2013   #13
Samuel if you get your ECU read by a garage with a good code fault reader it will tell you all you need to know instead of you guessing/looking yourself.
Old 13-02-2013   #14
Moderator
Andy Monty's Avatar
as magic says.. The more you try the more fault codes it will log making diagnosing it even harder
Old 13-02-2013   #15
South Africa
It seems that's all I can do, I will find someone with a code reader
Thread Tools
Starting problem 2007 1.2 Active Tookapunt Lets Talk FIAT 1 27-02-2012 03:24
(T) 1.2 8valve engine help please martyn271985 Punto (Mk2/2b) 1 13-03-2010 13:31
(G) EXHAUST FOR MK2 8valve PAGE52 Punto (Mk2/2b) 2 21-09-2007 19:36
Ultimate Street Car 2007: 03-08-2007 - 05-08-07 dave Events 50 07-08-2007 09:30
(G) Fiat GP 1.9/130HP Sport (2007) Vs. Seat Ibiza 1.9/100HP (2007) my_6th_sense Grande Punto 43 24-07-2007 21:28
