Technical unable to change gears?
stockton on tees
My grande has literally just gave up on me, driving along about 40 in 4th put the clutch down to change gear and nothing happened, gear stick will only move backwards and forwards (as if it was 3rd and 4th) but its not changing, still drives fine and clutch operates fine, there wasn't even any noise when it happened just seemed normal till it wouldn't let me select a gear?
I'm thinking its going to be gear linkage related but I need as much advice as there is out there as I'm skint and don't want to garage it unless necessary
