![]() | #1 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 ![]() | ![]() Hi, I have a grande punto 07 reg 1.4 dynamic dualogic (semi auto) version. Every time I open drivers door I hear a whirring sound (not a prob think its supposed to do that) after reading some other threads I'm sort of understanding the noise is something to do with a hydraulic pump priming something??? So my first question is what is that pump called? I asked in a local garage and the guy just looked straight through me! ![]() Ok well the noise has stopped and everything else works stereo, engine, heaters lights wipers everything is running just fine.... Go to put it in gear either auto or manual, and I get a beeping "check transmission" see handbook! Can anyone please shed some light I have disconnected re-connected battery I have cleaned all fuses what now HELP!!!!!!! ![]() ![]() ![]() ![]()
![]() | #2 |
![]() | Re: Grande punto dualogic 1.4 It's the gearbox hydraulic pump. No special name really. So it now doesn't prime the gearbox when you open the door? That'll be why you're getting the gearbox fault. Start first by checking all of the fuses for the Dualogic system ![]()
__________________ Most Easterly Panda's - Panda'ing in East Anglia ![]() Stockest of mk2 Panda Parts, PM for any parts requests ![]() 1993 Classic Panda Selecta, 1989 Panda 750L, 2015 Kia Soul EV, 2009 Qubo Dynamic Dualogic WAV & 2005 Panda Climbing 4x4 (LPG) ![]() |
![]() | #3 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 ![]() | Re: Grande punto dualogic 1.4 Fistly thank you for replying, I've checked all fuses ie engine bay glove box etc and all fuses are fine, so am I needing a new pump? And if so do you know if a normal garage can fit this or if I have to take it to fiat? ![]()
![]() | #4 |
![]() | Re: Grande punto dualogic 1.4 It sounds like you might need a replacement pump. Might be worth checking the heavy duty plug in the cable to it first though, and then giving it a thump to see if you can get a little more life out of it. Any garage can replace it, however only Fiat, or someone with MultiECUscan.net software can bleed the hydraulic system after, if the system isn't bled the car will still work, but be very jerky and lumpy with gear changes.
![]() | #5 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 ![]() | Re: Grande punto dualogic 1.4 Apologies for how dumb I'm about to sound, but this is my first car and I don't know too much about cars in general although I'm trying to pick things up as I go, you said about the heavy duty plug and weve spoke about the pump where do I find this stuff I assume its under the car and not in engine (told you I'd sound dumb lol) if I jack the car up would I be able to see what I'm looking for? Many thanks ![]()
![]() | #6 |
![]() | Re: Grande punto dualogic 1.4 It'll be around the gearbox, within the engine bay ![]()
![]() | #7 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 ![]() | Re: Grande punto dualogic 1.4 Thanks mate ill have a look tomorrow ... I'm sure you'll b hearing from me again lol ![]()
![]() | #8 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 ![]() | Re: Grande punto dualogic 1.4 Hi again told u I'd be back! If I had a multiecu scanner could I fix this myself provided someone installed a new pump?
![]() | #9 |
![]() | Re: Grande punto dualogic 1.4 ![]()
