FIAT Auto Specialist Team
Old 28-01-2013   #1
Anti-lag ftw!
Reuuk's Avatar
Trader Rating: 1
Reuuk is part of the official FF Events Team :)
Reuuk has donated!
Babe Jump Champion, Sofa Longjump Champion, Space Explorer Champion
Grande's Wiring Loom
as the title says..
Does anybody have a copy of the Internal Loom for the Grande which shows
example
greenwire - (indicatiors)
purple - electric windows
green - c/l
etc etc etc
pref for the loom behind the kick plate or back of the fuse box..
I've checked the the 'security section' for fitting alarms to the existing looms but the Grande isn't listed D:
wouldn't be the same as a Corsa would it?
Thanks.
this is as far as I've got D:
I need the diagram for the loom that goes to the back of the car.
follow me on Instagram: @reuuk
Mini Cooper S & Abarth 500
Reuuk is offline Reply With Quote Quote
Old 28-01-2013   #2
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: Grande's Wiring Loom
Is this the oem alarm your trying to fit?
this works via the can network rather than individual signals
Fiat been fiat never seem to keep to the same colour codes
from memory my old gp indicators were pink and pink and black stripe
the e learn manual doesn't show colours from memory but does show pins at the body computer
Thanks Reuuk thanked for this post
Massive gash
Just a little touch up
Old 28-01-2013   #3
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
You need to fit a canbus compatible alarm. Any none canbus alarm is asking for problems. When you fit a canbus alarm this is done using wirin PIN numbers and not colours
Dislikes Andy Monty disliked this post
Most Easterly Pandas is offline Reply With Quote Quote
Old 28-01-2013   #4
Anti-lag ftw!
Reuuk's Avatar
Trader Rating: 1
Reuuk has donated!
Yes I'm fitting a Canbus compatible alarm, I'm just looking into different methods. I can connect a non canbus to the grande if i don't want to use the current keyfob etc and want to loose the indicator flash etc.
such a pain this canbus malarkey haha
can you recomend any alarms? I've been looking at the falcon predators and the Fiat OEM meta alarm. but cant find any features for it :/
Old 28-01-2013   #5
Trader Rating: 2
Canbus is the future Reu lol. Tbh once your fitted one you'll realise that in practise they're a lot quicker and easier to fit.
I've fitted a proline to the Stilo, and fiddled with the Meta on the Bravo. I'm looking at getting a Meta for the Panda we've got also. I like the proline on the Stilo but not found them for sale since buying it off of eBay some years ago unfortunately. I'd be tempted to steer clear of some of these cheaper eBay canbus alarms though.
Likes Reuuk liked this post
Old 28-01-2013   #6
Moderator
Andy Monty's Avatar
on the gp there is two wires to the bonnet catch one goes to earth the other to the siren... then the siren wires to ground and two wires to the base of the fuse box (can h and l) That's it in the engine the mounting stud and nut is already there for the siren
then inside the car mount the 2 ultrasonic sensors and run the cables behind the dash to behind the glove box
then connect to the h and l can lines
hazard circuit
live and ground
you will need to dismount the body computer to do this and to get at it you will need to drill out the rivets on the cover plate
Massive gash
Old 28-01-2013   #7
Moderator
Andy Monty's Avatar
oops fat fingers sorry @Most Easterly Pandas
Massive gash
Old 28-01-2013   #8
Anti-lag ftw!
Reuuk's Avatar
Trader Rating: 1
Reuuk has donated!
thanks for the replies, I spoke to fiat they said they would supply and Fit me an alarm for 230
I'd much rather attempt fitting it myself even though its completely foreign territory for me :/
I'm guessing the Body computer is the one behind the glove box?
I think Ill go for the Fiat factory one and go from there :/ Eeek!
Old 28-01-2013   #9
Trader Rating: 2
Yeah it's on some Fiats mounted back to back behind the fuse box. Not sure if its like this for GP though.
Old 28-01-2013   #10
Moderator
Andy Monty's Avatar
can see one of the plugs you need to open in the pic (cut cable tie) unclip lever and open plug use the mini cable locks (think mini scotch locks then rebuild plug one wire literally shoves into the plug with the built in self gripping pin
can't remember my last go having the metal plate I mentioned above
Massive gash
(T) Wiring Loom Andrew Wright Uno 3 07-04-2011 21:52
(G) wiring loom sandipm Grande Punto 15 08-02-2009 15:19
(T) Wiring Loom Dave-M Barchetta 2 17-12-2006 17:06
(G) Wiring Loom roo Ulysse 1 10-09-2006 15:39
