Thread Tools
Old 28-01-2013   #1
Catch me if you can :-)
jonathaneuk's Avatar
jonathaneuk has donated!
Exclamation My morning startup problem (video)
So, finally got it on video, of my morning startup issue.
Splutters when turn on, then dies, then second time stays running.
This is every morning I get this problem. It's a 2007 1.4 8v with 40,000miles on.
What could this be ?
It's not all about the power!
jonathaneuk is offline Reply With Quote Quote
Old 29-01-2013   #2
Re: My morning startup problem (video)
Anyone ??
Old 29-01-2013   #3
Moderator
Andy Monty's Avatar
Andy Monty has donated!
battery, earth lead, or Map sensor are all suspect
https://www.fiatforum.com/grande-pun...-drop-off.html
Massive gash
Just a little touch up
Old 29-01-2013   #4
Moderator
Andy Monty's Avatar
oh and check your antifreeze it looks like water
Likes Jordan92 liked this post
Massive gash
Old 29-01-2013   #5
Battery been tested, cleaned earth points ect... And the coolant has just been changed :-/ maybe that needs changing ? Could that be a issue ?
Old 29-01-2013   #6
Moderator
Andy Monty's Avatar
not with the starting but it looks like water the correct antifreeze should have been used to protect the engine and cooling system what colour is it? the wrong stuff can cause corrosion in the engine and radiator......
if you have checked those next the map sensor needs checking both barometric pressure and air temperature
Massive gash
Old 29-01-2013   #7
Quote Originally Posted by Andy Monty View Post
Well I complained to the garage a couple of months back that the coolant looked black and dirty, so they changed it for me so I don't know what they have used.
Which one should I use and ill get some and start fresh ?
And the map sensor how do I check this could be the problem ?
Thanks mate :-)
Old 29-01-2013   #8
Moderator
Andy Monty's Avatar
Quote Originally Posted by jonathaneuk View Post
Thanks mate :-)
see the guides section I would flush the system several times e.g. fill and drain before refill with decent stuff wrongly or rightly use commas offering (red)
to measure those things you need a obd code reader the sensor I got came from ebay from this seller
http://item.mobileweb.ebay.co.uk/vie...id=35590509000
Massive gash
Old 29-01-2013   #9
I see, okay ill do a full system flush then, and get some red stuff?
Old 29-01-2013   #10
Moderator
Andy Monty's Avatar
yes mate I'd open the rad drain and drain out whilst putting a hose in the header tank keep flushing with clean water until it runs clear
Massive gash
Old 29-01-2013   #11
Got ya ! Right I know what I'm doing tomorrow ! Thanks mate :-)
Old 29-01-2013   #12
Moderator
Andy Monty's Avatar
Massive gash
Old 29-01-2013   #13
Yep just been looking at it there :-) need about 5l of coolant red OAT, will follow the steps, seems fairly easy :-)
Old 29-01-2013   #14
Moderator
Andy Monty's Avatar
well about 5l of mixed using the comma stuff its 2.5l of water and 2.5l of violent concentrate
Massive gash
Old 29-01-2013   #15
Yeah :-) ill do that thanks
Thread Tools
(G) Serious starting problem this morning.... Fariniac 500 19 18-01-2012 18:41
(T) Fiat Bravo 1.4 startup problem fabiomsouto Bravo / Brava 1 06-06-2011 20:47
(T) Startup problem jordanr Punto (Mk2/2b) 3 28-01-2011 18:01
(T) Problem starting in morning tabbs Scudo 23 19-12-2010 18:42
Vista Startup Problem LizzieR Computing 4 15-04-2009 19:45
