Technical Got a problem with my Grande Punto
extige
Hey guys, My name is Rizvan, I'm new on this forum. Before 2 months I bought a Fiat Grande Punto and it seemed like a good car, economic, 1.4l Engine. Recently now that the weather is quite cold in the morning when I go to work, I've got this problem the engine starts but it goes off again like it doesn't suck the fuel. maximum 4 times than on the 5th time it starts and works fine during the day.
Any Idea where the problem might be ? Please do not hesitate to give your opinions
Welcome to the forum Rizvan :wave:
i take it the car starts then the revs (rpm) slowly decrease and the engine stops.......
I had this myself on my last car
https://www.fiatforum.com/grande-punto/226978-starting-problem-revs-drop-off.html
first check the battery is healthy (decent garage to do a Load /capacity test)
next if ok
check the earths
https://www.fiatforum.com/grande-punto/226978-starting-problem-revs-drop-off.html?p=2651258
then look into replacing the map sensor (y)
Hey there Andy, thank you for the reply. I now know where the problem, is because I also read the other what problems they have had, and it is almost the same problem with mine. I just don't know is it simple to change it or does it have to be connected with a computer or something like that. I couldn't find any youtube tutorial. so I would be very thankfull if you could probably explain it in a simple way how to change it.
ps: Thank you again
Regards,
Rizvan
