im Axle Specialists
Old 26-01-2013   #1
x Alex x has donated!
binding rear o/s caliper
hi all
had a binding rear caliper now for ages, it's pretty much wiped out the disc and worn much of the pad down to the limit.
i've had the caliper off, to me it seemed to be the handbrake mechanism causing the problem, i bent the arms of the clip for the mechanism in such a way to make it stronger and even slackened the handbrake off a bit, but it's still binding!
anyone had similar? done a search but couldn't find anything similar with a fix.
i've looked for a new handbrake mech clip but can't find one, is it just a case of getting a new/reman caliper?
low profile sports tyres and a binding rear caliper don't make for good snow grip
Grande Punto 1.9 Multijet Sporting
x Alex x is offline Reply With Quote Quote
Old 26-01-2013   #2
Re: binding rear o/s caliper
Tried winding the piston back into the caliper a bit? Might help
healy2210 is offline Reply With Quote Quote
Old 26-01-2013   #3
take your caliper off break it apart(not literaly) grease it up n rebuild
shaun6017 is offline Reply With Quote Quote
Old 27-01-2013   #4
i wound the piston back, cleaned it up and copper slipped it.
the problem seems to lie with the hand brake mech so i rebuild/clean of the piston wont help
(G) Ducato Rear Brakes Binding dragons213 Ducato 23 30-04-2015 08:35
(T) More rear brake binding Rizz Punto (Mk1) 2 09-04-2011 14:31
(G) Rear Brakes Binding jawz Stilo 6 17-06-2010 19:17
(G) rear brake binding markgriffiths Punto (Mk2/2b) 1 03-05-2010 19:39
(T) rear brakes binding teulk Punto (Mk1) 11 30-10-2005 12:45
