| Thread Tools |
![]() | #1 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 ![]() | heater airflow lame! ( not the usual problems ) Hi Guys! So.. its snowing, and ice is forming on the inside of my windscreen while I'm driving! Time to fix the heating system. 1) Pollen filter - non-existant. but its housing nice and clean. 2) Fan motor, clean as a whistle, and spinning nicely! 3) No blockages that i can find. 4) Air is hot.. but even on 4 setting, very very little air comes out. not enough to de-mist my windscreen on cold days. what should i check next !?
![]() | #2 | ||
Posts: 3,094 Thanks: 84 Trader Rating: 0 ![]() | Re: heater airflow lame! ( not the usual problems ) If there isn't airflow then surely that has to be the fan motor dying? Are the settings 1,2,3,4 all the same air flow?
![]() | #3 | ||
Posts: 20,605 Thanks: 731 Trader Rating: 0 ![]() | Re: heater airflow lame! ( not the usual problems )
![]() | #4 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 ![]() | Re: heater airflow lame! ( not the usual problems ) Thanks for the fast reply! ![]() Hi, if you use the diverter valve ( inside / outside air), does it make any difference..??, ![]() If there isn't airflow then surely that has to be the fan motor dying? Are the settings 1,2,3,4 all the same air flow? Setting 1 is virtually nothing. Setting 2... barely anything. setting 3.. i can just about feel it. setting 4... its definatly blowing, but very very slowly. I can hear the motor spinning.. sounds good. I've had it spinning outside of its housing, and the motor seems to spin fine. Speed settings work as expected.
Thread Tools | |
Punto (Mk2/2b) Problems as usual! | James MK2 | Newbie Central | 1 | 31-07-2012 18:55 |
![]() | GymJunkie | Grande Punto | 1 | 27-01-2011 14:16 |
![]() | jaberwocky | Punto (Mk2/2b) | 8 | 14-04-2009 17:53 |
![]() | Stilo Stew | Stilo | 3 | 30-01-2007 23:53 |
![]() | VUK | Uno | 13 | 12-06-2006 16:36 |
