Thread Tools
Old 15-01-2013   #1
Possible EGR??
Just a quick one hopefully. I've done a search on this on here and have symptoms for two possible causes i think?
Basically, i have a 1.9mJet and started her up this morning, started fine but then started to stutter and misfire. There was a large amount of smoke coming out of the exhaust and when i put my foot on the accelerator (not in gear, just sat on the drive) revs would only climb to around 1500-2000 with a large plume of lightly coloured smoke.
I had a similar problem on my Stilo previously and it turned out to be EGR valve. I'm just after confirmation really.
Also would this contribute to intermittent starting problems? ive had my crank shaft sensor replaced due to non starting issues which solved it but it seems to be creeping back in, i'm hoping this is linked to whatever problem i have now.
Was going to try a clean of the EGR to see if it cures the problem.
Thanks in advance.
Current: 56 FIAT Grande Punto 1.9 MJET Exotica Red - Projector headlights, hid bulbs, pressed metal plates, updated red badges, gloss black grille, more to follow
Formally: 03 FIAT Stilo 1.9 JTD Dynamic 115 Broom Yellow - Abarth Side Skirts, Black Chrome Blades, Lowered 30mm, Badgeless Mesh Grille
Rackham115 is offline Reply With Quote Quote
Old 16-01-2013   #2
Re: Possible EGR??
I took a chance last night and took the EGR valve off and gave a good clean. Loads of sh*t came out, fitted back together and it would appear problem solved. Car runs fine now (well it did last night anyway). It did struggle to start but not sure if that was related or whether its the extremely cold temperatures outside?
Old 16-01-2013   #3
Re: Possible EGR??
hows it been running 2day??
shaun6017 is offline Reply With Quote Quote
Old 19-01-2013   #4
Re: Possible EGR??
Quote Originally Posted by shaun6017 View Post
Seems to be running ok in respect of working but its still not perfect. Every now and then accelerating from lower revs it takes a while to pick up, even the turbo doesnt kick in where itusually does, and then all of a sudden all the power suddenly cuts back in as if its been building up while its not been running.
Its nothing too serious to worry about at the moment, its running and thats enough for me at the minute
Thread Tools
(T) EGR (again) TwyRob Doblo 15 28-11-2017 15:38
(G) EGR Cleaning (Wynns EGR 3) AndyRKett Punto (Mk2/2b) 0 15-07-2012 23:27
(T) Faulty EGR symptoms but not EGR??? Bushboy Stilo 27 10-01-2011 15:25
(T) Egr cculha Grande Punto 3 07-05-2010 09:44
(T) Egr Maus Doblo 9 18-12-2006 11:54
