Hi All
I have a 2007 1.4 8 valve GP, noticed on these cold mornings that the heater is a bit rubbish - the temperature gauge goes up to mid way but the output isn't that hot - even on 3 on the fan its a warmish blast to the legs. Any ideas? I know the fan often packs up but that's working fine. Pollen filter changed in August.
I suspect is't a weak system, also engine isn't highly tuned and not pumping out loads of heat, probably over cooled so it's no furnace.
Not sure if they do winter thermostats, think the 8 valve engine is same one as the 1.2? I used to have an old Astra that always ran cool in winter and had gunge under the oil filler cap, resorted to blocking off some of the radiator to get it warming up properly.
Ta
Ta
