Thread Tools
Old 11-12-2012   #1
My Other Car Is A V8!
Rob93's Avatar
Rob93 has donated!
Daily Power Steering Failure - Temperature related?
Hi guys, I know what causes the electic power steering to fail but would the low temperatures at at start-up be the cause of daily failures? (Its only within the first few minutes of moving)
Rob93 is offline Reply With Quote Quote
Old 11-12-2012   #2
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Re: Daily Power Steering Failure - Temperature related?
Quote Originally Posted by Rob93 View Post
Probably, low temps kills battery's often
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 12-12-2012   #3
Moderator
Andy Monty's Avatar
Andy Monty has donated!
if your still on the original battery you have done very well....... mine died on my 1.2 within 4 years......
Likes Rob93 liked this post
Massive gash
Just a little touch up
Old 13-12-2012   #4
Rob93's Avatar
Rob93 has donated!
Okie dokie
Old 13-12-2012   #5
Rob93's Avatar
Rob93 has donated!
Quote Originally Posted by Andy Monty View Post
Oh that could be a potential problem then! Yeah it is still original! Only covered about 35k though?
Old 13-12-2012   #6
Moderator
Andy Monty's Avatar
lots of short journeys can be worse for a battery than a car that piles on the miles it takes between 5-10 miles to just put the charge back in from what is used starting the car,,,,,, not to mention what the car uses especially at this time of year fan... lights. heated rear screen for example....
get the battery properly capacity and load tested but chances are that is your issue
Massive gash
Old 13-12-2012   #7
Rob93's Avatar
Rob93 has donated!
That's my problem then, work is 3 miles from me :/
I do go for long drives afterward though.
Thanks for this info!
Old 13-12-2012   #8
Moderator
Andy Monty's Avatar
if that's the case sticking it on a intelligent charger every now and then would help top it up and preserve the battery
Old 19-01-2013   #9
Rob93's Avatar
Rob93 has donated!
It has been given a new battery and I drive it enough every day for it to put charge back into it, yet I still get the power steering failure with out warning???
Old 20-01-2013   #10
Have your alternator checked for output. Had similar intermittent problem for a while then after some weeks the battery light illuminated, followed by the whole lot of warning lights, again followed by total blackout and engine cut-out. The battery had allowed immediate start-up but then, without the amps from the alternator, finally packed in. New alternator and battery back to A1 performance.
exalfisti is offline Reply With Quote Quote
Old 26-01-2013   #11
Rob93's Avatar
Rob93 has donated!
Quote Originally Posted by exalfisti View Post
Had the alternator checked
Unladen - 14.1
Laden - 13.2
Had a new alternator fitted next day and still have the same problem :/
Could it be a fuse relay?
Old 26-01-2013   #12
Moderator
Andy Monty's Avatar
voltage never tells the whole story did they test it at the alternator or on the battery posts? how many amps was the alternator pushing? (its the ampage that charges the battery more than volts,)
could also be the earth strap which goes from battery to chassis leg to gear box
this is why thorough diagnosis at a decent Fiat dealership or Independent is a must as i guess so far you have thrown the best part if not more than £200 at it and still not fixed it..... people moan at diagnostic costs BUT a £60-£80 plug in (Which is often refunded if you have the work done at the garage who diagnosed it) might have pointed to a £25 cable for example
Likes Most Easterly Pandas, Rob93, ChrisUK liked this post
Massive gash
Old 27-01-2013   #13
This might point you towards the right (and costly) direction!
https://www.fiatforum.com/grande-pun...-steering.html
georgios1976 is offline Reply With Quote Quote
Old 28-01-2013   #14
Rob93's Avatar
Rob93 has donated!
I'm probably going to sell for an Abarth at the end of the year so i will leave it unless it gets worse. I have cleaned and protected the earthing points last night so i will see if that helps
Old 29-01-2013   #15
Rob93's Avatar
Rob93 has donated!
After cleaning the earthing poitns, all is back to normal
Thread Tools
(T) power steering failure/air bag failure, no radio or clocks Davies5390 Grande Punto 2 02-03-2012 21:39
(T) Power Steering Failure AdynGill 500 10 08-03-2011 20:16
(T) power steering asr failure esp failure bigwig Stilo 6 25-04-2010 20:39
(T) Power steering and temperature light on. gemymcd Punto (Mk2/2b) 6 15-06-2009 14:20
(T) Engine Control System Failure and Power Steering Failure oc99 Punto (Mk2/2b) 2 18-05-2008 15:54
