Old 07-12-2012   #1
Grande punto won't start?? HELP??
I bought my grande fiat punto 6 weeks ago with no warranty. It is a 1.4 16v sporting 2007 model... Had no problems until this morning... The car will not start atall and doesn't make any noise.. It says check power steering? All the electrics are still work.
If anybody has any idea on what this could be I'd be greatful of the help, thanks!
Kay009 is offline Reply With Quote Quote
Old 07-12-2012   #2
Egypt
Re: Grande punto won't start?? HELP??
change the battery
Likes Kay009 liked this post
yoko is offline Reply With Quote Quote
Old 07-12-2012   #3
Don't want to sound daft but would the electrics still work if the battery is flat??
Old 07-12-2012   #4
puntopower!
matty seasider's Avatar
Trader Rating: 6
matty seasider has donated!
Quote Originally Posted by Kay009 View Post
would your kettle at home work if power was off?
PUNTO GRANDE SPORTING MJET :
RED-DOT REMAP RUNNING 194.8Bhp 328.8 ft-lb torque
matty seasider is offline Reply With Quote Quote
Old 07-12-2012   #5
1.4 16v Nissan Note Visia
Magic Johnson's Avatar
Magic Johnson has donated!
Do you have breakdown cover? If home start included great, if not push it 250m and you should be fine. Otherwise buy a DC multimeter and test the battery for the right Voltage.
Magic Johnson is offline Reply With Quote Quote
Old 08-12-2012   #6
Egypt
yes it will work at starting the car draws a high current if the car battery is weak it will not feed the starter motor with the enough current but it can feed other electronics
give it a test open your main beam light and try to start the car if the lights dim more than normal then it is a battery problem
i am an electrical engineer by the way
Old 08-12-2012   #7
Forum Moderator
T14086's Avatar
T14086 has donated!
The car makes no attempt to start and power steering error message is displayed;
I would check the 2 fuses on battery + terminal then read the error codes. Was the car ok before this happened? There was a ignition switch issue on early models as well which would cause a no crank situation.
Old 08-12-2012   #8
Quote Originally Posted by matty seasider View Post
Nope but the person below cleared that question up lol. Thank you everyone I don't have breakdown cover but someone coming to look at it today. Hoping it is just a battery problem and not something more expensive.
(T) Grande Punto - EBD Failure - ABS - Won't start! pooonto Grande Punto 11 21-05-2017 20:00
(T) Grande Punto won't start Dan No More Grande Punto 7 09-01-2013 16:12
Grande Punto Grande Punto 06 won't start - Immobiliser Light Staying On gemasue Newbie Central 0 28-06-2012 13:46
(T) 2006 Grande Punto 1.2 won't start - garage can't find fault fugsgal Grande Punto 13 19-03-2008 22:41
