Technical Little advice please
Bury
I did some winter checks today and found issues
- Coolant with slow leak, a common issue but it there a common place it leaks?
- Oil level still max but alarmingly I checked the oil cap and found yellow gunk inside the cap. Head gasket symptons? Could this be linked to first issue?
I religiously never exceed 2,000rpm before its at temp. Only get used at weekends, will sit for about 3 days aweek usually :rolleyes:
Greg
This could be the cause, if it sits for long periods cold getting condensation in there. Try cleaning the gunk, and see if it returns quickly or not (y)
Ye i cleaned it out. I'll drive back to uni (Manchester to Huddersfield) and check again tomorrow.
As for coolant, no its still same colour just less of it :bang:
Thanks for replies
Hmmm this was after a long journey yes? It can often appear if you only do short journeys that don't allow the engine to warm up fully.
It returned quickly. Checked today and the yellow gunk was back. Also the coolant is leaking quicker. Bottle was nearly empty
You will get yellow gunk if you drive like miss daisy or do lots of short runs...
the engine takes a very long time to get hot......
Have you tracked your coolant leak down yet?
and for the love of got at this time of year do not keep on filling it just with water get some properly mixed antifreeze in...
also check the water pump area (need to remove cam belt lower cover to check) for signs of leakage..)
if you 100% can't find a leak only then would i think about getting a head pressure test done...
Firstly no I am not just adding water ;)
Secondly over Christmas I did do only really short journeys. Only 3 mile to work. Then 3 miles back.
Lastly I have not found the leak yet. Having it checked over Friday. I am hoping it is the water pump as I need to do a cam change
Remember anti-freez is poisonous, particularly to pets, so don't allow large amounts to leak out on your drive or you might kill the neighbour's cat.
Update: It was a clip. The guy reckons it was broke at last service as another pipe looks to have been replaced/fixed :(
Always serviced at Fiat :mad:
Anyway cars back to perfect & now its sunny I need to start burning fuel in the name of country road fun
Nearly 3 years with my T-Jet and I still love it
