Oh cool, yeah i have a android phone. What else can you do on this then ?
Nope no cambelt
Nope.was a.wiring.fault,.something.from.the alternator
Wait...wait...so a garage told you your GP was fubar'd and all it was was a bit of wiring?
OR am I missing something?
Stop making so many different threads haha!
That makes no sense?
A wiring/alternator issue causing coolant to go black and presenting head gasket symptoms?
Have you checked to see if any nuts/bolts have been disturbed recently (eg, exhaust manifold heatshield). Sounds to me that they've done the head gasket and don't want to admit it and potentially have you try to back the car after all the issues you've had.
If they have disturbed the cambelt, the EML flashing @ 60mph/3000rpm will be down to a sync-ing problem between the cam and crank sensors caused by not resetting the system after doing the job. If this is the case, the fault code will be for a generic misfire.
