Blocked scuttle drains..
has your car got a pollen filter?
Pollen filter at the moment no, but there is a slot to put one in, and the scuttle drains you mean the 2 rubber hoses coming from the scuttle panel I've checked those and there both clear, same behind the wipers aswell, looks abit dirty but nothing clogged up behind the plastic trim.not sure where abouts the air is drawn in from that the heater blower pulls in, presumably from the engine bay via some ducting not sure where that would be though.
My heater motor only comes on when I knock it or give it a small tug and only will stay on for 1 min then goes off. I've removed it and found it to be wet inside the motor.not sure about fixing the motor as I dont know how, I've got a new motor and resistor on order and I've got a pollen filter to test out depending on what sort of heat I get if I can get it working again,but I need to make sure nothing is going to get wet again ?
