Technical Exhaust information/advice required
Tom61
Well my 2007 Grande Punto 1.2 8v is just about to clock up 150,000 miles.
It still runs well, but unfortunately rust has just eaten through the engine sump. In order to replace the sump I assume that I'll have to move the exhaust out of the way (it still has all the original exhaust!), I thought rather than remove the manifold, it would be easier to disconnect the flange connection just below the catalytic converter. Am I correct in assuming the flange is held together with two studs and nuts? If this is so then the nuts have rusted away making it impossible to remove what is left of the nuts from the studs. Any suggestions would be gratefully received.
Thanking you in anticipation,
Tom.
I'm assuming the studs are fixed rather than separate bolts? Might be too rusty to tell. If you can get access I'd cut the studs off with a hack saw or angle grinder, drill new holes through the stud flange and put some bolts in.
If access isn't good then the above might be impossible.
Hi James,
Followed your advice, managed to angle grind and drill the nut? end of the studs off and hammered the remaining part of the square shanked studs out, and fitted it back up with ordinary bolts.
Now waiting for the sump to arrive, and hoping it'll fit without having to take the manifold off.
Many thanks, and best wishes,
Tom.
