Technical Battery cover
DriGP
Mosta, Malta
Hi all,
During cold weather i noticed that my grande punto is taking longer to start. If i but a battery cover/blanket, will this help?? are there other things that i can do for it to start without hard starting??
Thanks in advance.
Hi all,
Thanks in advance.
How old is the battery? It is probably better to bite the bullet and replace it, rather than trying to nurse a weak battery along. Weak batteries can cause all sorts of odd electrical errors on the gp so, imo, not worth it.
If you insist on keeping the original battery, pushing the clutch in whilst starting saves the starter having to spin half the gearbox; but the difference is small.
The battery is only one year old so i think it is still good. The engine is petrol 1.2 2006.
Hi Andy. Do you mean the earth wire which is connected to the battery, by earth strap ?? If not, where is this earth strap located and what is the typical resistance ??
Thanks.
