Hi All,
This evening when i left work i had some trouble starting my '56 Grande Punto 20k miles
I'm just after some advice or to see if anyone else has had a similar issue..
when i turned the key the radio lights, and fan's but it didn't start no clicking or nothing no attempt to crack and the immobility light goes out.
I attempted to turn the key a few more times with no success taking the key in and out of the ingnition. Colleague came over and i was showing him what was happening and it started.
Drove it home and then went to the shops about 30mins ago and at my house it had the same problem again eventually starting leaving the shops again a few attempts taking the key out etc and it started.
turned on and off a few times at home and it seams fine, just don't want it to get worse if its a quick fix.
I've noticed when i go from the first key turn to the second (when it should crank) the fans stop and only the battery, engine and oil lights stay on but once its started there are no warning lights.
Any Idea's?
Thanks.
Any Idea's?
Thanks.
