Mozella
My 1.4L 16v Grand Punto Sport (I think it’s called “Sporting” in the U.K.) 70kw (engine code 199A6000) is due for a cam-belt change. I don’t trust my local mechanic (I live in Italy) to do the job properly because I’m pretty sure they simply mark the old belt and put the new one on the same way.
I’m an experienced home mechanic and I’ve performed plenty of cam belt changes on other engines, including my rather sophisticated Desmo Ducati. I’m not worried about doing it correctly; however, I’m put off by the high price of the special tools. They look nice and I can see the advantage of using them, but I hate to nearly triple the cost of the job by purchasing tools which I’m likely to use only once. I also don’t particularly like paying the high cost of having someone else do the job, especially if I can’t trust them to do it properly.
It seems to me that I can make or improvise my own tools. Matching the exact height of the 2 adjacent cylinders seems like it would only take a pair of equal length rods and possibly some careful measuring and double checking. The driven pulley locking tool is certainly nothing I can’t make with a piece of steel bar, a drill, an angle grinder, and 10 minutes time. The tensioner tool looks almost like my circlip pliers or my bent needle nose pliers. And finally, the cam-locking pin looks like something I can make out of a piece of rod or perhaps improvise with a socket drive extension.
So, assuming I follow the correct procedure outlined in the maintenance manual, where am I going wrong? Has anyone done this job properly with the correct tools and then realized that the tools, as nice as they are, simply aren’t required for the one-time user, especially considering the price? Comments?
