We've had the timing belt changed today, along with the oil leak fixed, which turned out to be the blanking cover for the second cam next to the cam pulley.
Anyway, I was there as the guy was putting the finishing touches to the job.
The car started up as usual, he left it to idle, and after about 30 seconds, it did an almighty spaz. The revs dropped, the car almost cut out, then it picked up and idled as normal.
The car drives as it normally does with no irratic running, but the "Check Engine" message is flashing with the ECM light on.
He reset it with his diagnostic tester, but it's still on.
I'm going to take it for a 50 mile commute tomorrow, to see if it clears. He's suggested we take it back if it's still on after the weekend, but any thoughts.
