Englishlion
- Oct 18, 2012
- 5
- 3
I know lots has been posted in the past regarding this issue but I don't think my question is covering old ground again. I have searched and read.
My problem is the overheated/melted/burntout resistor pack connector one.
So on to the repair -
I have ordered a new resistor pack from an ebay seller and I have a used connector and cables coming from a fiat breaker. My intention is to cut off the old connector, fit the new resistor pack, trim the wires on the 'new' connector and then join the new connector to old loom via a terminal block.
So my question is: what rating of terminal block do I need? At the moment I have a 15A one coming from another ebay seller, will this be sufficient? I think it should be fine but then I don't want to fix the car just to burn it out completely a few months later!
And can anyone see any flaws in my intended 'fix'?
