Old 02-09-2012   #1
Do I have aircon?!
Hi, random conversation with the mechanic this week - me - 'it's a 16v non-aircon' - him - 'it does have aircon - there is the pipe, there is the valve and the pump is running'. But there is no switch for it on the dashboard - the space between the air recirc and the rear window button is blanked off. I think I remember the dealer saying they'd replaced the heater control, so did they replace the entire panel? And could I replace the panel with one that does have the appropriate button, and if so where could I get one from?
Thanks from a slightly bemused GP driver!
GloryBoy is offline Reply With Quote Quote
Old 02-09-2012   #2
769cc Mayhem!
Didge3's Avatar
Didge3 has donated!
Re: Do I have aircon?!
Trying to get my head around your post, do you mean you bought the car and it didn't have the aircon button? So you assumed it didn't have it but turns out it has the aircon compressor etc?
If so do you know the trim model of the car, Active, Dynamic, Sporting?
If you're not sure does it have alloys or hubcaps?
It might say it on a sticker near the drivers door lock, open the drivers door and below the lock (on the car body not the door itself) it should have a sticker, I believe this says the trim level of the car.
Didge3 is offline Reply With Quote Quote
Old 02-09-2012   #3
Trader Rating: 1
Or a picture of you engine bay
2007 Exotica Red Grande Punto track project. Sporting parts available
Drives: 2008 Chemical Grey Grande Punto Sporting 120 T-Jet
GYoung87 is offline Reply With Quote Quote
Old 03-09-2012   #4
Hi, thanks for the replies. The car is a 1.4 16v Sporting, with the lovely StarJet engine. Well, it was lovely until it started playing up about three months ago, now it is a howling, underpowered nightmare. But that is another matter.
I bought the car 18 months ago from the dealer, he'd supplied it originally and taken it again in px against a new one. He said he'd replaced the heater temperature dial because it was stiff and wouldn't turn very easily. This makes me wonder whether he replaced the whole of the panel but used a non-aircon panel rather than one with a button for the aircon.
The mechanic pointed out to me what he said was the aircon pipe, the valve for regassing and the compressor pump, which was running. I'd wondered what the pipe was for - I'd assumed it was something to do with the bonkers StarJet system.
Any ideas? Bemused doesn't begin to cover it!
Old 03-09-2012   #5
Trader Rating: 1
Sportings have aircon as standard
Old 03-09-2012   #6
Cool, that is good to know. So I guess I need to source a replacement panel - where could I find a part number?
Thanks for the replies.
Old 03-09-2012   #7
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
I can't see how the compressor was running of there was no way of switching it on
Pic of your engine bay and center console (control panel) plzkthx!!
Eklipze3k is offline Reply With Quote Quote
Old 03-09-2012   #8
As has been said, you definitely have air con but I'm suspicious of the dealers story. Replacing the control panel because of a 'stiff button' sounds like a load of bull to me, 'hid the fact in has air con because the compressor is shot and costs £600 to replace' more like.
To the dealers credit though, he didn't try and pass it off as having air con and hope you didn't notice it was broken.
jameshobiecat is offline Reply With Quote Quote
Old 03-09-2012   #9
Quote Originally Posted by Eklipze3k View Post
Probably just the compressor pully turning with the actual pumping bits de-clutched.
Likes Eklipze3k liked this post
Old 03-09-2012   #10
Simple- all the switch does is put a request to the Body Computer- "switch on the compressor". The BC then acts on that request and will continue with that course of action until the "off" request is given by pressing the switch again. If the A/C was not turned off before the panel was swapped, the last request will still be active (A/C "on" in this case).
I've had this before with a duff hazard switch which failed after being activated. Even with the switch removed and thrown away, the hazards continued to flash when the ignition was on, until I replaced the switch and pressed it to send the "off" request.
Thanks Andy Monty thanked for this post
D4nny8oy is offline Reply With Quote Quote
Old 04-09-2012   #11
4.5k for insurance :O
cainy1989 has donated!
if the pump has been running continually for 18months, apart from those days the temp is below 3 degrees then that might explain the low power and iffy running, i know on my 1.4 16v bravo if the AC is on it takes about 87bhp leaving me with 3 for the car
cainy1989 is offline Reply With Quote Quote
Old 05-09-2012   #12
But if it had any gas in it the op would surely have felt it (chilled air entering cabin) and if it had no gas then the compressor would have encountered little resistance and therefore not sucked up much power.
Old 05-09-2012   #13
Quote Originally Posted by jameshobiecat View Post
On with low fan speed on the feet at mid temp, I am assuming most people wouldn't notice the difference.
TallTom is offline Reply With Quote Quote
Old 05-09-2012   #14
But it has been that way for 18months. Surely in summer the temp dial would have gone down and the fan speed up. I'm tempted to credit the op with the wherewithal to notice.
James
2007 T-Jet Sporting, Red, Skydome
Old 05-09-2012   #15
If the gas level drops too low, the compressor is disabled to prevent damage from a lack of lubrication, although the button on the dash will still light-up.
It's also disabled under conditions where full engine power is needed.
(T) aircon jp1949 Ducato 0 09-08-2011 20:20
Had AirCon now No AirCon what belt do i use tomo187 Lets Talk FIAT 0 09-08-2010 14:40
(G) aircon is on or off whogiveaffff Punto (Mk2/2b) 4 10-05-2009 12:58
(T) Aircon. swansea2007 Stilo 4 26-03-2008 21:49
(G) Aircon Sometimes ???. Jacko27 Stilo 2 08-06-2006 10:47
