Technical new speaker cable install
Right, sorry for posting yet again but can someone advise.
Iv looked but not sure:
So i can get inside and feel the gromit from the inside, but how can I possibly work around this?
Current wiring goes under here
Current wiring again, im going to follow the same route but i just dont know how to go through the existing channels to the doors.
sorry not been on for a while right i eddited a pic for you
where the arrow is there should be a screw around there and one in the rear of it by the seatbelt rail then the highlighted panel just pulls off just do it slowly the that is drivers side the second part has two crews one under the fist pannle and one near the fuse box u will see it after u undo the first side
that may make it all clear for that step
ill do a couple of sections will make it easier to follow
http://s1081.photobucket.com/albums/j360/chris599/?action=view&current=grandde.jpg
and the second bit of trim u have to remove on the passenger side mine had one crew and one panel clip just to beware
Chris you're a star mate.
Thanks a lot!
I just have a short amount of time friday so the more I know the quicker I can get it done, I'll be able to do it from that info.
As for the wires to the headunit for the speakers, they'll be useless now wont they?
Hopefully the wires wont get damaged with rain etc due to being outside the rubber :D
Well mine seem to be Oky since u can run cable out side it made of rubber just make sure u fi threw the door grommet use screw driver pop a hole I. And head they will be useless but leave them run just for when u want to sell car good luck
well done mate glad u did it for got to see how u got on mines annyoing mee got bit of interference with window moters dunno why but all good
