General wishbone bush 1.4 8v
chris9
can i get a bush in and not the hole part and if so were 1.4 8v sporting :confused: thanks guys
There's two bushes and a ball joint on front wishbone?? So you need to be a bit more descriptive, but each part is available if you look on eBay. Rear bush needs a hydraulic press as does front bush. Old ball joint needs the 3 fixing studs grinding off, then an aftermarket all joint kit comes with new bolts
