Hi all, my first post here having recently bought a 2007 1.4 Dynamic Sport, impressed so far with the car. One thing I have noticed is that it mists up quickly especially during the damp weather.
I have checked for dampness and all the carpets are dry, no pools of water. Recently repaired the water leak fault near the brake servo and the boot area is dry.
I suspect that the air recirculation switch may not be doing anything and the valve could be stuck closed - the button lights up but there is no change in the airflow or noise of any valve moving.
On previous cars I have had you could hear something move when it was switched on or to test set to cold air and with the fan on maximum to the face vents the airflow would change slightly when the valve closed. I had a look today under the heater fan next to the left of the pollen filter is a multiplug connector fixed to the clear plastic trunking, would anyone know is that the valve or is it further up near the dashboard past the fan motor? Has anyone had a similar problem and managed to repair or fix the valve so it is open all the time?
